Antique Crackle
Antique Crackle
Antique Crackle
Tomm
>Can hide glue be used in place of the Antique Crackle that is sold for use with milk paint? Are they basically the same material? Thanks for your response.
Re: Antique Crackle
Re: Antique Crackle
NickTuzzolino
>I took a finishing class once where we used plain old yellow carpenters glue, slightly thinned, and painted over it with latex base paint for the krinkle effect. Worked well.
Re: Antique Crackle
Re: Antique Crackle
Bill White
>Behr makes a crackle medium. Just finished a piece yesterday. Top coat needs to be a flat finish. Heavy coat of medium = heavy crackle. Light coat = light crackle. Brush it on for irregular cracks, or roll it on for even cracking. I clear coat after with a water based int./ ext. poly. It doesn't yellow.
Bill
Re: Antique Crackle
Re: Antique Crackle
Robin Corell in Atascadero CA
>I would sugest you post this over on the hand tool section where there is a greater collective of older methods and materials. I use hide glue as a glue and I know it is used for crackle finishing but I don't know the mix ratio.
Robin
Re: Antique Crackle
Try Woodworking Magazine
Al Kapocius
>Woodworking Magazine (related to Popular Woodworking Mag), issue 10 had an article on glue and crackle finishes. Available for $6 through download. I'd give details, but issue was pulled before I got back.
Al Kapocius
Re: Antique Crackle
Yes, and here's how
Michael Dresdner
>Paint your base color, the one that you want to show through the cracks. When it is dry, coat it with a coat of liquid hide glue. Thinner hide glue makes smaller cracks; thicker makes larger cracks. Wait until the glue partially sets up, to the point where it is no longer wet but still squeaks when you gently rub a knuckle over it. That's usually about two hours. Paint over it with any latex paint in the color that you want to be the main color, but do it quickly. It will crackle right behind the brush in under a minute as you go. Don't go over it a second time or manipulate the paint. Put it on and move on. It's a quick and easy way to crackle any common latex paint.
