THE WOODRAT IS BACK!
OT Gas Cooktop repair
Nat Robison
>I have, what I believe, is a bad igniter on one burner of my gas cooktop. The gas is working fine and the burner can be lit with a match. Disclaimer: I've never repaired a cooktop or igniter before.
Since the rest of the igniters work, is it likely just the igniter on the affected burner as opposed to the whole electrical system on the cooktop??
If the connection is sound, Can the small ceramic piece that holds the metal rod that delivers the spark be bad??
Where do I start on this problem??
Re: OT Gas Cooktop repair
George Koch
>Nat, first check the screw that holds that igniter to the rangetop. That acts as a ground and if it is loose or corroded it will cause the problem you described. And yes the ceramic can develop a crack and therefore will not arc properly. Hope this helps. George
Joseph Mulherin, Sr
>Nat, and all others reading this: there is a website you can go to for some knowledge on repairs to almost every sort of appliance....
www.repairclinic.com
Update
Nat Robison
>As I probably should have done before posting my original question, I tried a working electrode on the defective burner. It's still defective. So all the electrodes are ok, right??
Is the problem likely in the wire coming from the spark module to the defective burner?
piezieo electric unit
Robin Corell in Atascadero CA
>For your applicatin I would try one of the starters from a working unit in place of the defective one and if it works then look for a replacement. I have found several web sites with parts that are half the price of my local store and that includes shipping.
Some piezieo electric units are outragously expensive($80) and some are cheap ($20)not sure the difference.
Robin
Re: piezieo electric unit
>Is this a piezo igniter? My outdoor grill has a piezo igniter - push a button and create a single zap. But my gas cooktop in the kitchen creates the spark with power taken from the wall outlet - turn the knob for that burner to the ignition position and zap-zap-zap until it's lighted.
If the problem unit it is built like that, there is a single power supply and a switch built into each knob supplying a spark to that burner. If some are working and another is not, the power supply is OK. The switch built into that burner knob may be bad or something in the connection or ground may be bad.
What I would do: turn off the gas, disconnect the electrical power, trace the wires to each switch, look for bad connections, and use a continuity tester (or ohm meter) to check the circuit and pinpoint the problem. Be careful testing with power on - that's high voltage.
Re: Update
Ralph Lipeles
>Can you swap the wire that feeds the non-firing electrode the same way that you sweapped the electrode?
Ralph Lipeles
Steve in Fresno, GOOO DOOOGS!!!
>Spark Module, get the model number and I'll get you the part number. Oh and don't buy from repairclinic their prices are very high.
