Alternatives to Varnish
Allan D
>I've been finishing my Mission furniture with lacquer because I like the minimalist look of polished wood. I recently completed a coffee table however, and decided I needed something more durable because it's going to have drinks and food spilled on it, feet placed on it, and just generally be subject to more abuse.
The polyurethane varnish, as I suspected, looks much thicker and less attractive to me. Is there anything with the look of lacquer and the durabilty of varnish?
Re: Alternatives to Varnish
Steve Schoene
>Of course, there are the conversion varnishes and catalyzed lacquers that spray on a very lacquer like finish, though they generally require serious spray facilities to deal with the even more noxious fumes.
Have you consider a non-polyurethane varnish? Waterlox, as an example, is a wipe on varnish, that will be quite durable and will allow a protectively thick coating before it starts to develop the plasticky look of too thick polyurethane varnish. Polyurethane (the single part consumer grade) tends to get that way quicker because it is often subtly less clear.
Re: General's PU Gel Topcoat
Jerry Draper
>I've done a half dozen coffee tables in solvent based NC, acrylic, or alkyd lacquers that have been in continuous use with kids and partyers over the last ten years. None show any more wear than if they were finished with a conversion or catalyzed product. I currently use SW Alkyd Medium Rubbed Effect lacquer.There's no need for anything else.
Clint
General's HP poly
Robin Corell in Atascadero CA
>I have been using General's High perforance polyurethane for over a year now with wonderful results. It is a water based poly acrylic blend that can be sprayed or brushed. depending on the weather and the noumber of previius coats it is sandable is as little as 20 minutes. It sands just like nitrocelulose and buffs out the same as well. once its cured for a couple of weeks it is very resistant to abrasion and water marks from glasses. I have even used it over a coat of tung oil with equally good results. I almost forgot to add that it is water clear and has a UV inhibiter. Actualy in color tests it has a very slight yellow/amber color as opposed to a blushish tint but once on the wood it has less color effect any of the other finishe I have used.
Robin
Fred Davis
>Clint is right about Lacquer , our coffee table is a massive thing I built twenty five years ago and the finish has held up far better then you would have imagined..
That would include the wear and tear of a daughter and boy friends when no one was looking.
FredD
sure, lots of possibilities
Bill Tindall, E.TN
>1. conversion varnish
2. Thinned varnish or any kind.
To meet meaningless(in terms of benefit) EPA regulations formulaters have had to increase solids in varnish. If you thin it it can be made to lay close to the wood and look like shellac, lacquer or about anything.
