Rockler quick release wood vise
Robert Henderson
>I just bought the Rockler 9" Quick Release Wood Vise on sale. I know that the jaws should be parallel in the horizontal plane, and they are. But shouldn't they also be parallel in the vertical plane?
When the jaws are closed, the jaws meet at the top but there is about a 1/8" gap between them at the bottom. Is this normal or should I return the vise?
Re: Rockler quick release wood vise
Robert, this is normal...
Stuart Hough
>The jaws are normally set at about a 2 degree inward incline because metal normally bends slightly under clamping pressure, and this will allow the jaws to end up parallel, resulting in fairly even clamping pressure across the face, and untimately, the workpiece. At least that is how it was explained to me by an old, grizzled, very wise woodworker.
not on my vise
Robin Corell in Atascadero CA
>I don't think its normal and on my Emmeret the jaws meet perfectly parallel in the vertical direction. And of course in the horzonatal they adjustable. There is the possiblility that perfection was the norm when my Emmeret was made and now they have an excuse for why imperfection is prefered.
Robin
Re: not on my vise
mike@American Sycamore
>Robin:
you are talking about a high quality well made expensive unit, not a cheap knock off made in China. Precision comes at a price. I am sure that Roberts vice will work just fine for woodworking.
Re: not on my vise
Tom MacGregor
>My guess is that it's a quality issue that might not be solved by a replacement of the same model. Try using it & see how well it works. I like having the jaws on mine faced with 1/4" maple which could easily be shaped to adjust the closure if necessary.
design feature
>This may be by design. I'd far prefer a bench vise tight at the top rather than loose at the top. Wouldn't be too hard to taper wood facing if needed.
From the Highland Hardware (Woodworking) catalog concerning Anant's model of the Record quick-action bench vise:
"Jaws toe in slightly toward the top edge to assure positive clamping under heavy pressure."
They note that "Anant purchased the tooling & casting for Record's discontinued bench vises, & after inspection, we see no substantial difference between Anant vises & those formerly made by Record."
Re: not on my vise
Fred Davis
>Robin,
it's not fair comparing a Emmmeret vise to run of the mill knockoffs of lesser products.
Kinda like expecting a Crapsman tool to live up to it's advertising ;-))
FredD
By design, and type of vise
Michael Dresdner
>I have found that most metal working vices with metal jaw faces are parallel vertically, but some types of woodworking vices are specifically designed with a slight vertical angle to allow top clamping. The common guitar maker's vise is a good example. It is designed to hit at the top first. I can't vouch for the designer's reason for it, but I can tell you it is incredibly handy to have it that way.
