Spindle sander question
Paul Woolson
>I've got a Delta Boss with the 4-1/2"? drums. I need more height for an operation that I do frequently. Does anyone know if Jet's taller drums will fit on a Delta? (of course I'd need to fabricate some sort of longer bolt to hold it on)
Re: Spindle sander question
Depends on the attachment method
>I've owned a couple spindle sanders in my day. The old Boice-Crane type had morse tapers on the spindles. My old Enlon had a threaded stud. Taller spindles may work fine on your Delta, but in the long run, the spindle drive may not be adequate to handle the increased leverage of the taller drums. I'd say, go for it if you don't need that capacity often. Otherwise, look into a beefier sander.
Re: Depends on the attachment method
Robin Corell in Atascadero CA
>Send me a PM and I will send you some pics and measurements of my old powermatic/jet spindles. If it will work it is yours for a donation to WC equal to or greater than the postage. I won't be able to get the pics to you until after Thanksgiving weekend.
Robin
Fred Davis
>Ellis ,
you mentioned one of my most used sanding tools , a Boice-Crane oscillating spindle sander that was given to me many years ago by a stair shop owner who "said he didn't have a use for it and his men abused it" , this machine takes nine inch sleeves from half inch dia. to three inch dia.
FredD
