Best Blades for a MiniMax S45?
Ken Bellock (Houston, TX)
>I'm buying a used MiniMax S45 tomorrow, and I need to get some blades for it. I searched the archives here for reviews of blades, and saw Timberwolf blades mentioned several times. Are there any new opinions on the best blades for resawing and cutting curves on this bandsaw, or any recommendations for vendors? I see Lee Valley sells some, but not sure if they are the right size. Does anyone here have a MM S45? Can you tell me what size blades I will need to be looking for?
Thanks, and I hope everyone here has a happy Thanksgiving!!
Ken
Re: Best Blades for a MiniMax S45?
Dick Coers
>I've owned one for at least 15 years. Only had to replace the switch in that amount of time. I did add the Carter ball bearing guides, and really like them. The saw takes a 3634mm blade, (couldn't resist since that's what is inside the door) or 143.07". 144 " will work just fine. I haven't bought a blade in a couple of years. I buy coils of stock off Ebay and silver solder them myself. For heavy resawing, I have ordered Lennox blades from Pipers Saw Shop. Those were 1" Woodmaster C blades, 1.3 teeth per inch. They are basically sawmill blades, but are really cheap compared to resaw blades. My favorite blades for general work is 3/8", something like 4 or 5 teeth per inch. You can resaw with a blade like that if you let it do the cutting and take your time feeding the stock.
>Lenox Tri-Master carbide tipped 1/2x3tpi for resawing. Timber wolf 1/4x4tpi for general use.
Clint
Woodslicer worth a look
Robin Corell in Atascadero CA
>I have used a wide selection of blades over the years on my own bandsaws and at the verious shops I have worked at. I've used Lennox Starret and several others in various tooth, pitch and sets. The very best blades I have used are the Woodslicer blades from Highland Hardware. Having read the reviews and hype and used the blades I can say that the hype and descriptions are pretty acutrate. I would make one small clarification. the manufacturer claims that thy will last twice as long. This is true but you will only get the exceptionaly smooth surface quality for the first half of the blade life and similar quality of cut as a cheaper blade for the second half. all in all it still works out to be worth the money.
Robin
Kevin Adams
>Hi Ken--
I have one of the new S45's and it's really a great saw--you're going to like it. It runs very smooth with plenty of power. I keep a 1/2" Timberwolf blade on there all the time and use it for resawing, ripping, and other rough work/large curves. I also have a small Inca where I keep a 3/16" blade (one of the LV's) for more intricate work. With the 1/2" blade on the S45 I track the teeth right off the front of the wheel (flat tires).
Let me know if you have any other questions. Enjoy your new saw.
Kevin
Re: Woodslicer worth a look
>Iturra Design sells the same blade as the Woodslicer under the name Bladerunner and I think they are a tad cheaper. (Highland has the Woodslicer name) I've bought some of both and like them. These blades are 3/4 TPI (variable) which claim a smoother cut. However, they are still carbon steel and won't last as long as HSS, although at 1/2 the cost. I'm saving for a good carbide-toothed blade.
Iturra also sells Starrett and Lenox blades. I don't think they have a web site yet but if you call and tell them you application, they may have a recommendation. 866-883-8064 (BTW, I have nothing to do with Iturra other than having spent a lot of money there.)
The Iturra catalog is worth asking for - it's about 250 pages full of mostly useful information, reviews, and bandsaw accessories (and some other tools). The guy is a bit opinionated but entertaining and seems experienced.
