Assembling, leveling cantilevered shelves
Jay Crutzfeld
>In the process of assembling a 6' cantilevered entertainment center made of solid ash uprights routed through 3/4 plywood shelves (with 1'' ash facing). The uprights lean backward onto the wall with no additional mechanical bond (nothing is attached to the wall studs). The shelves are fixed to rails running front to back that are attached to the uprights. The center span is 43 inches. The two upper shelves will have additional support from single lengths of 3/4 angle steel to prevent sagging below the centerlines. The bottom shelf (which will hold a 90 lb television) will be supported by a 1 x 8 inch piece of (4/4) ash. The rails for bottom shelf will be attached to the uprights with lag bolts (not through bolts), the upper rails will have screws. The boards are bowed up noticeably, making leveling a challenge. Wondering whether the downward deflection of the shelves over time will put too much lateral pressure on the uprights as they settle onto the underlying supports and if there is a good way to accommodate that movement. Also, the bows and slight warps in the shelves makes leveling with a spirit level or laser difficult, so we are having to fine tune the levels by eye. Wondering if there is a better way.
In the attached picture, the project is supported temporarily with clamps and two stools.
