round toothpicks
round toothpicks
round toothpicks
Robin Corell in Atascadero CA
>I am getting near the end of my supply of Richwood round toothpicks and I seem to remember reading that they ceased production. I have always used the same brand because I use them as dowels to pin together small things. The Richwood toothpicks are .085" diameter which is a #44 drill. Can anyone recommend another brand with good consistency and a convenient drill size? And as long as I am asking weird questions does anyone know if the Japanese toothpicks are metric and how big? (They have the notch on one end to make it easier to break)
Robin
Re: round toothpicks
>I use bamboo skewers when I need a small diameter dowel. They're easy to handle, come in a couple diameters, and can be scraped down for really small diameter holes. And they're a lot tougher than birch (?) toothpicks.
Clint
Chuck in ND
>Try a Cracker Barrel restaurant General Store if you have one near you, not sure if they have a website. I picked up a batch a couple years ago.
Bill Earl
>I have some Japanese toothpicks that measure 0.09" (+- 0.001).
They are 2.85" long. 2.1" to the first notch.
John McGaw
>You can probably find them locally although the source might not be one you'd normally go to. I believe I've seen them at one of the "dollar" stores for example. But it things get really desperate, John Wilson sells them as Shaker box supplies but after shipping they could get expensive.
steve mackay
>Diamond is the big boy in the biz. They're very consistant. I go through toothpics by the box and can tell ya' you probably don't need to worry about the brand. I wind up taking what I can get in the grocery store. I tried Dollar Store stuff and it stinks. We all know most things there are "seconds" and toothpicks are no exception. Wound up pitching out six boxes of "good deal".
Ask Norm Abrams
Al Kapocius
>Remember the program teaser for Yankee Workshop a few seasons back? Norm turn a log down to a custom toofpick. Mebbe he has a tape and detailed destructions.
Al Kapocius
Bamboo through a dowel plate
David Barnett - SW Florida
>You can get perfect dowels down to very small diameters by making a simple dowel plate. For very small drills you can skip a few in-between sizes. Bamboo is easily forced through the holes. Skewers, as Clint suggests, are ideal, but you can split a bamboo chopstick and have plenty of stock.
Thin annealed tool steel works just fine without any subsequent hardening, and even mild steel works for bamboo. Just support the plate over a hole in a board if it flexes too much.
This is how tiny trenails were formed for admiralty plank-on-frame hull models.
Lee Gordon
Lee Gordon
>If it will help you to search, the Japanese word for this type of toothpick is "yoji."
Unfortuantely, that is also a proper name, including one of the tattoo artists from the TV series "Miami Ink" so you'd have to refine a Google search to be a little more specific.
