200+ woodworking book reviews
Lignum vitae... questions
Scott in Montana
>Good morning all,
I am curious regarding lignum vitae. I like the green oxidized color and am thinking about using it for a slender legged stand under a Krenov style cabinet.
Now the questions. Is it subject to splitting after it is finished? Does it tend to warp? Does it maintain the green color? Is it more difficult to glue up than teak? Will a tung oil/poly finish be suitable?
I'm sure there are other things I should know. I welcome any and all input.
Thanks in advance,
Scott in Montana
Re: Lignum vitae... questions
Re: Lignum vitae... questions------WebKitFormBound
Winton Wood------WebKitFormBoundary3X6lJE9G+ofV2Og
>My vote for finish is no finish. Just plane/spoke shave it then take wads of the shavings and burnish the wood. If it looks like it needs something after that rub it with some bees wax.
------WebKitFormBoundary3X6lJE9G+ofV2Og3
>Hey I am new here. How do I correct my entires ? I want to change "wodd" to "wad". Or am I destined to be put down here as an idiot for all time ?
Dan Donaldson
>You cannot correct it yourself, but I just checked it and somehow it magically fixed itself ;-)
Robin Corell in Atascadero CA
>It is nearly impossible to glue. You will be able to wipe it with acetone and do a glue up and it will hold for a while but the wood will continue to exude a waxy coating and this will eventualy cause a glue joint to fail. I have not trid all types of glue but PVA, polyurethane, and epoxy have all failed for me. I have never tried a finish on LV but it will polish up nicely and after a bit it will look cloudy and grimy. This is the natural wax that it exudes and it is easily buffed off and regains its polish. In my experiance it is probably the most stable wood. It rarely moves while sawing and once shaped it stays.
Now for the bad news, that nice green color fresh cut color will oxidize to a chocolate brown.
Robin
Fred Davis
>The natural wax Robin speaks of in Lignum Vitae is one of it's assets .
For instance I used to be seriously into Leather work and one of the tools I use a lot was a circle of Lignum Vitae with a thumb hole a groove in the outside edge.
This was used to burnish the edges of belts and the waxy nature of the wood lent it's self to this operation better then anything else.
FredD
Green to brown and back to green
Scott in Montana
>Here's something interesting. I bought a few board feet of this to play with and ran a piece through the planer; the fresh cut face was a honey brown color which was nice but not the color I wanted. After about three weeks, the fresh cut face is back to the desired green.
Anything is possible and nothing is as expected here in Montana!
Scott
Re: Green to brown and back to green
>It can take a year or more for it to change to its final color. The sap wood always stays a creamy yellow/white.
Robin
>I smooth and burnish leather braid work with a Lignum vitae tool I made. It works better than bone.
Robin
