Lubricating chisels on a hollow chisel mortiser?
Bob S
>I have several hundred square holes to drill for an upcoming project using my hollow chisel mortiser and am curious what I can use to lubricate the chisel to ease the cutting without interfering with gluing later. Possibly paraffin or something like that?
Thanks Bob
Re: Lubricating chisels on a hollow chisel mortiser?
Robin Corell in Atascadero CA
>I have never had a need for lubricating the chisel on my mortiser. You may want to make sure it is polished, particularly on the inside.
Robin
Me Too
Mike Fitterling
>How about a microcrystalline wax such as Renaissance wax? I haven't tried it on my chisels, but I use it on my plane bottoms, table saw top, jointer top, bandsaw top, etc.
Re: Lubricating chisels on a hollow chisel mortise *LINK*
J D Thomas
>Bob,
I recently cut a bunch of mortises in QSWO and used a product called OptiCut XL. It worked great.
BTW, I don't agree that mortise chisels don't require or benefit from lubrication. I found the difference using this product to be amazing as the to ease and quality of the cut.
J D Thomas
ThomaStudios
OptiCut @ Rockler
Larry Clinton At Frankfort (Central)., Indiana
>I use the Boeshield drycoat blade & bit lube. I have my bits sharp and polished and still have some issue with heating when I don't use the lube. A spritz of the dry lube and the tool run quiet and cool. I cut several mortises between sprays. It also seems to make the chisels cut a little easier.
What about 'chain lube'?
Bob S
>Thanks for all the info. Do you think I could use 'extra dry chain lube' for bicycle chains? Contains PTFE but I don't know if it has silicone or something that would screw up finishing later.
Bob
Larry is right on target with this stuff, but ....
Art Silva
>it is very important to keep a 1/32" clearance between the drill bit and the conical inside surface of the chisel. Happy holes! Art
Re: Larry is right on target with this stuff, but
Fred Davis
>I use a dime to set the chisel clearance and Paraffin for the lube, haven't tried any of the more expensive lubes , but anything to reduce friction will extend the life of the tool , including a Clico bit stone used in a Brace.
FredD
Allan D
>I've found it help a lot to have a shop vac hose held right up close to th bit when you are boring to take the chips away. Otherwise they sometimes jam up in the hollow bit. The bit stays cooler also.
