Cherry Coffee Table
>Good Morning Friends,
This actually started out as a four poster bed. SWMBO, doesn't particularly care for high bed posts, and told me to table the idea. So I made a table instead.
Considering the relative small size of the living room, I thought a drop leaf design would be appropriate, and chose a 36" X 42" elliptical shape as target dimensions for the top. As I played around with the "look" of the top, location of the rule joints, and the width of the drop leaves, the elipse became more highly modified and the overall width with leaves raised became 37 inches.
We decided to install a shelf to help balance the top. Its curved shape at the extended ends compliments the top. In retrospect, I should have raised the shelf to the level of the dropped leaf. It would have looked more pleasing. Further, I should have made the end rails of the frame with a slight bottom arch. Maybe I should call it a prototype. SWMBO likes it, though, and commands that it stays.
I bought a rule joint router bit set from Eagle America. Rule joint hinges were from Lee Valley. Positioning the hinges with respect to the rule joint was not instantly successful. However, once the hinges to one leaf were inlet a second time and damage repaired, the leaves looked and operated perfectly. I edged the top and leaves with a simlple chamfer. The table frame is mortice and tenon joinery. The shelf is secured by pocket screws.
George
