Sharpening frostner bit?
John Veerkamp, Western Mo
>What's the best way for me to sharpen a 2 1/2 inch forstner bit? mine is getting dull.
Thanks,
JohnV
Thanks,
JohnV
Re: Sharpening frostner bit? *LINK*
GalenV
>At least one video you may want to look at. Others video show different type of bits. I don't have to much luck and probably should have them sharpened by someone else for what the larger ones cost.
http://www.ehow.com/video_4418691_sharpening-forstner-drill-bit.html
SonnyEdmonds
>First you'll have to defrost it...
Then...
(Don't you just love typos?)
Re: Sharpening forstner bit?
Parisian, VL
>I just go at my cheap ones with a small file followed by 600 grit wet or dry glued (or wrapped around) any convenient piece of scrap wood that is a close fit. I know they aren't perfect, but it does the job and I'm back to work fast.
Victor
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>While I sharpen almost everything by eye like that., I would like to have given the end results a good close inspection. I have to say, that I have some suspicion about the casual use of that final stone that he touched up with.
There was some mention recently about using the magnifying visors. I wouldn't think of doing my bits without one.
Usually all you need to do, is try to maintain the same sharpness angles, then grind until all of the shine is gone from the edge. Until you get to the point where you know when you want more or less sharpness angle or hook etc. for the given situation.
Not too difficult, can be tedious...
John in NM
>The two chisel edges should be self explanitory, just use a file or stone to do the bevel and then clean up any wire edge running a stone over the "flat" side (geometry is just like a plane blade). The part I find really tedious is the circular part. I do that with the edge of a thin stone - a nice coarse india or crystolon stone - and it still takes a while. I never seem to have a dremel and a little wheel at the right place and time. Anyway, I've found I can skip sharpening the circular edge now and then, depends on how long I let the chisel edges go.
>I use a Dremel with a white conical wheel to do most of the surfaces. I use a hand held diamond hone to sharpen the flat surfaces. It doesn't take very long to do it.
Thanks for the help everyone
