>Being able to post pictures is a great part of this discussion, whether you're asking questions, or looking at someone's work. I often find though that I have to repeatedly crop, resize, & lower the resolution of pics I'm posting in Photoshop in order to get them below the smallish 80K limit. The results are often a picture which is smaller & of lower quality than I would have liked. I'm wondering if there is any way this limit might be raised, say, doubled, perhaps?
If you have Photoshop, it's far easier to use the Save for Web feature on the Files menu. Open the dialog then click the little triangular options button on the right and pick Optimize to File Size. Type in 80 and Photoshop will figure the optimum JPG compression to make the file size as close to 80 as possible without going over.
Of course, it does help to resize and crop a bit first, but it's surprising how large a photo can be compressed to 80k and still be usable, depending on content of course.
As a test, lets see if this 2560x1920 photo of some of my gavels comes through.
>Although uploading photos to a web site somewhere and embedding the link into a message can make for some beautifully formatted messages, I personally don't like to see it.
The reason: if the pictures or the hosting site are ever removed or changed, the pictures in the message go away! I've found many examples of this when browsing archived messages on this site and others. Some webboards, in fact, prohibit embedding links to pictures for that very reason.
>I use an older version of PSP (version 4.14) because I can't stand the newer versions. With version 4.14, at least, there is no automatic way to get a given file size so it takes a few tries. (Shouldn't take more than three tries.)
1 - crop as much as possible - select area, Image/Crop
2 - resize as desired - Image/Resize (600 to 800 wide is a good size)
3 - open save dialog, File/SaveAs, choose new file name, JPG type
4 - standard encoding will work although progressive works better
Choosing the compression level is the part that takes a few tries. The compression in PSP is specified from 1 to 99, where the larger the number the smaller the file size on the disk.
The quickest method of finding the best compression value is with a "binary search": pick a number, say 40, and save the file as a test. If too big, pick another number 1/2 way between 40 and 100, say 70. If still too big, pick 1/2 way again: 85. If too small, pick 1/2 way between 70 and 85.
The object is to pick the smallest number that makes the file size as big as possible but still under 80K. As mentioned, this shouldn't take more than three tries. After you do it once or twice it shouldn't take more than one or two tries. (Note that due to the way the JPG compression algorithm works, a photo with a lot of very small detail will need a higher compression value than one with less detail, for example, one with a background that's mostly sky.)
For a specific photo, the bigger the compression number, the smaller the file size but the worse the picture can look. However, even with relatively large compression values the picture can still look fine. For the one below of me grabbing a log for the sawmill, I picked a value of 60 and it made a file less than 70K. Numbers as high as 85 or 90 will still result in usable photos in most cases.
I do have a newer version of PSP on my wife's computer across the room, but I'm too lazy to go check right now. If the method I described above doesn't work with the version you use I might be talked into checking the other machine.
>here is a nice program http://www.irfanview.com/ Like if you pic is 41.1 you can resize to we will be 9.70kb after the resize the pic will be the same You have to watch if you get the kb's to low the pic will start to get blurry Most sites give you a nice size of bit's to use I have used this ifranview lots of time for different sites and works fine
>On the "Save for Web" dialog look for a little button near the upper left consisting of a black triangle in a round circle. Click this for the options menu.
Little triangles are used throughout Photoshop for options and function menus, for example in the Layers pallet. They are easy to miss.
Note, you can also do everything you need (but crop) to make an uploadable image from the "Save for Web" dialog without using the option menu - make sure JPG is set near the top, set a reasonable Image Size in the tabbed dialog and Apply, choose either the Optimized or 2-UP tab for the display, and adjust the Quality sider until the file size shown at the left below the image is below 80K. An under-used feature of Photoshop helps here to ease into the best quality setting: adjust the slider to get close then click on the quality input box once to place the cursor there, then use the up and down arrows to adjust the quality one unit at a time while watching the file size number. This is usually easier than using the slider. But using the "Optimize to File Size" dialog at the expense of just three clicks.
>Somewhere in the neighborhood of 600 to 650 pixels wide is a good size for viewing on the boards for most people. It is not hard at all to get a picture that size that still has plenty of resolution for viewing.
>If there is a post of pictures where it is something that would be of interest to many and it cannot be shown well except by multiple pictures, I can set it up for you on the WC site and post the multiples. (as long as it doesn't get out of hand ;-) Examples might be views of a project that needs several sides to show it well or a set of pictures that show a process where it is very inconvienient to go to separate posts. I can only do this in the evening, so it would usually be an overnight type of thing. Something to keep in mind.
>After poking around in PSP I had pretty much given up on going directly to that magic number 80. You seem to have confirmed this.
Several months back Derek or one of the other Australians on the board posted about a free download for photo resizing "JPEG Resampler" which is real easy to use. I use it and like it.
