Re: cutting 45 degree bevels on table saw
Jesper, Denmark
>Cutting near square boards on the tablesaw against the fance is usually asking for trouble. It is difficult not to twist the board and hold it against the fence at the same time as you push againts the resisting force from the blade. Never cut anything shorter than it's width against the fence.
Use a sled instead. Now you can hold the board firmly against the stop on the sled and the runner in the slot takes care of the twisting tendency.
The sled is easy to make if you do not have one. You can probably find a description in the articles section. Mine is a simple 1/4 inch plywood sheet with a � * 1 � inch stop 90 degrees to the fence with a wood runner in the slot.
