>I'd like to try out some ideas and make them in a smaller scale.
For those who make small pieces - do you generally use thinner lumber? I can thickness down to 1/4" without too much trouble. I could comfortable resaw thinner pieces also - I'd just have to work at smoothing them :).
How about small scale hardware? Sources?
What are some good scales to go for? 1:2, 1:3, 1:4...?
>3:1 or on an architects scale it is the one marked 3 will give you 1/4":1" I find this to be a comfortable scale for tables and chairs but for larger items I have used 1 1/2:1 the nice thing about using the 3'1 architects scale is that 1/4" breaks down with 1/32" incraments to represent 1/4" inch scale incraments.
To mill my lumber I use a 16" disc sander. I mark it off with a panel guage and then adhere it to a block of wood with double sided tape and sand till my mark disapears. If you lack a disc sander you could get the same results on a table saw, but I would definately use a zero clarance throat plate and make sure the sacle lumber is flush with the bottom of the block of wood.
when I design in scale I don't include edge profiles other than a round over or a bevel nor do I bother with any fancy joinery or rails and stiles or even hardware. for case goods I glue up a solid block and draw in the lines for the rails and stiles as well as the drawers.
I prefer bass wood because it lacks a distictive grain pattern which can be confusing. I also don't bother sanding or finishing.
the trick in photographing a scale model is to remove any background refrences to scale and lower your camera to a similar point s what you would use if you were photographing the full scale piece of furniture.
>Depends. Miniature is my stock in trade. If thickness of stock is what we're looking for you can go paper thin on the TS. If it needs to be clean go a bit over then run it on the bench sander applying preasure with the finger tips. Finnish up with a sanding block & calliper to check along the length. ( I missed the point did'nt I ? )
