>I just received a bid for a bathroom vanity with curved doors. My first thought was to cooper them since they will be of solid wood. But, I was wondering if a router set-up would be possible. For example, place glued up boards in between two plywood sides cut to the correct radius. The edges of the plywood cradle sit below surface of wood blank. Construct carrriage of 1/2" pipe that rides along plywood, router mounted to pipe and slides side to side. Use 1 1/2" straight bit, keep moving carriage along plywood, then cooper the inside of the doors. What do you think, too complicated, won't work, easier way to do this?>????? thanks for your thoughts.
>The biggest dificulty in doing curved doors is not making the blank for the panel but in making the rabbits and raising the panel. The method you chose for making the blanks may be influenced by if your jigs or forms can be used in the routeing process.
Here is a pic of a curved panel. The panel was made by edge gluing three boads with slight angles. Pinch dogs are the perfect way to clamp during glue up. I then used a block plane on the outside and a radius bottom plane on the inside. To raise the panel I used a large gouge and left the carving marks to complimnet the rustic nature of the carging and the hammered texture on the rails and stiles. If I had wanted a more traditional paised pael I would have used a combinatin of planes and scrapers.
to make the groove in the rails and stiles I used my router table and a curved fence for the rails.
>Howard, it isn't clear if you are making frame and panel doors. And I'm assuming the inside and outside surfaces are to be fair curves, right? In other words, you don't plan to just cooper some staves together and let the facets remain? And, one more question: Are these curves to be arcs of a circle or something else?
Regardless, you have a few construction problems to solve. If these will be frane-and-panel doors, the curved top and bottom rails should probably be laminated. Any other method will look unusual depending on the tightness of the curve. Bandsawing rails out of heavier stock, for example, will result in a bullseye grain pattern that you would probably find objectionable. Laminating allows you to select the exact face grain you want to see in the finished product.
The curved panels can be coopered and then faired with hand tools as someone suggested, or you could engineer some kind of machine/router process to fair the curves for you. Your suggestion, though I can't quite visualize how the pipe(s) relate to the router bit or the curved guide rails, sounds like a perfectly doable solution. We used to use big straight bits in routers to flatten slabs too wide for the planer. The more accurate you make the jig, the less cleanup you will have to do later. For the inside curve at least, consider a big core-box (round nose) bit instead of a straight cutter. The curved cutting edge will leave smoother ridges.
>Thanks for your comments. yes it will be a fair curve and part of an arc. What I was thinking was taking two pieces of plywood that would be cut to the same fair curve. The glue up top and bottom would be attached to the plywood. Two pieces of 1/2" pipe would be attached to the router plate allowing it to slide side to side. The pipes would ride along the plywood by slipping some type of bushing over them. Don't know how to attach a picture of this. I'll try to draw something up. Thanks again.
>I have used this exact technique to produce the curves in the headrest of rocking chairs. Instead of pipe, I used 2 long dowels, but in your case the pipe would provide more stability due to the width of the door. It is a slow process, you really can't remove much more than 1/8" per pass. Just make sure the jig is stable and your door is held tight. You may also need an extra long router bit to reach the surface. Good luck.
