Pear Wood Source?
Pear Wood Source?
Pear Wood Source?
Scott in Montana
>I need some clear pear wood for stringing inlay on a project I have coming up. A piece about five feet long would be nice if it exists.
Any leads would certainly be appreciated.
Scott in Montana
Re: Pear Wood Source?
Thomas S Stockton
>Start with Woodfinder. I used to buy all my pear from Gilmers in Portland.
Tom
Robert R. Clough - Thorncraft
>Another place to look is palletts (sp?). I often get pear wood from a local manufacturer. Obviously it needs careful working.
Robin Corell in Atascadero CA
>I have a friend that uses a fair amount of pear and he gets his from Gilmers. Ive seen what they ship him and it is some nice stuff.
Robin
Pear wood
Philip Duffy
>Gee, its too bad you are in Big Sky country as I have a pile of it outside my garage door. I could ship you some smaller pieces, but not a 5 footer. Let me know if I can help. Philip
Scott in Montana
>Good morning Thomas,
I looked over Woodfinder and was surprised that only one of the dozen sites that came up when I searched for pear wood had any dimensional wood; the rest had only veneers. The one supplier that did have lumber, only had very figured slabs.
I'm looking for a long piece to slice into 1/8" inlay. The table I'm working on is a bit over five foot long and the inlay will be left natural colored so I'm thinking that a scarf joint will eventually show.
I will check with Gilmers on Monday. Meanwhile, let me know if you think of anyone else that might be able to supply it.
Thanks for your help,
Scott
DP
>A source for you is Hearne Hardwoods ((888) 814 - 0007). Their website (http://www.hearnehardwoods.com/index.html) shows they carry pear in a variety of sizes from 4/4 to 12/4. Another source is Groff and Groff in Quarryville PA ((800) 342-0001). Don't know what they have in stock currently but I've seen pear there that would meet your needs. Both are reputable suppliers who are easy to work with. No affiliation.
My current project is with Pear,
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>However, the log that I got was only about 45" long. I sawed most of it to 12/4 on the woodmizer, and put it in the loft for about 5 years. It is killing me to cut it into small pieces now for the present job, but sometimes you gotta do what you gotta do.
This is really pretty in its even texture, and reddish into purple shading, but I am wondering if it would really be very exciting as a thin banding like you propose?
However, In your first post, you only gave one dimension, the length, of a 3d object, then later gave 1/8" as another. I don't know if that is depth or width? But it seems like cherry would be a good substitute if it is narrow.
I should be through cutting out my parts by mid week, and should know if I could spare you the left-overs if you are interested, drop me an email, and we can discuss it off the list, or I can send you a couple of pics to see if this will work. K
Re: My current project is with Pear,
Scott in Montana
>Hello Keith,
The commission I'm getting ready to start is a demilune table that will hold an original C.M. Russell bronze. The table will be roughly 62" long, by 27" deep and 35" high. It is being made out of instrument grade claro walnut with a bookmatched top. The legs, skirt, and top will have a very simple 1/8" string inlay paralelling the edge. This stringing will be an eighth inch wide and about the same in depth.
I hesitate to use cherry due to the photo sensitivity. I'm thinking that in ten years the cherry would be as dark as the walnut. I thought about using butternut, but thought it would be a pain curving in an area that needs a six inch radius. Pear is supposed to excel at this if heated.
I've seen traditional walnut pieces inlaid with strings of pear and thought it looked wonderful... even after 80 years.
So I'm looking for a 4 to 6 inch wide piece of 4/4 or 5/4, and as long as I can find.
Thanks,
Scott
Dale Lenz
Re: Not 5'...but maybe this will help(?)  *LINK*
Dale Lenz
Pear wood veneer
