need strong joint for long glue ups
>My friend Brad Sells is doing a sculpture for the local hospital and part of the sculpture is a rough representation of a DNA helix. What he needs to do is make the helix part which will be made from glue ups of laminated boards. We discussed it yesterday and ideally he's wanting to make it about 2 to 2 1/2" diameter and will do a gentle spiral 26 feet up. The glue up etc is not the problem. What we are wondering about is the best joint to use to glue the 6 or 8 foot sections together. I recommended what I think is called a Scarf joint. A long taper with a notch at both ends. He doesn't want to use the standard shaper type joint used to put molding together because it would give it a machine made cheap look.
How would you all join these part together and do you think the wood can stand up to the weight at that length. He plans to do a test shortly. He's still in the finishing stages of the 4 human figures right now. The man is about 9 or 10 feet tall to give you a sense of scale of this piece.
