Central Machinery Radial Drill Press
>Good Afternoon Friends,
I got a little bored this afternoon, and didn't feel like being out of the sunshine in the bowels of the shop. So I went over to the local Harbor Freight to buy some acid brushes, and a thumb wheel rachet driver set. I also looked at the floor model radial drill press they were selling for around $250.00 I have wanted a radial press for quite some time, as I would like to get into some chair making. The HF tool looks substantial, but I couldn't test it. Does anybody have one?
George
Re: Central Machinery Radial Drill Press
Re: Central Machinery Radial Drill Press *LINK*
Dan Mitchell
>George I've had the HF drill press in the link below for several years & have always liked it, quite substantial, though it's not the exact model you're considering.
Dan
http://www.harborfreight.com/cpi/ctaf/displayitem.
Carol - now back in Dubuque, IA
>Hi George,
I have had 2 radial drill presses. The first was an AMT (no longer manufactured) bench top. There was a decided 'flex' in the arm, the further out the arm was extended. That makes drilling perpendicular holes problematic, or holes at a specific 'set' angle. This reared its head one day when I reset the press to drill a perpendicular and discovered I didn't get one, no matter how careful I set the machine.
The one I have now is a Grizzly floor model. I have not had the need to drill holes with the arm significantly extended, but to date I have not noticed the same kind of flex that AMT displayed.
FWIW, I noticed the shipping weight to be 5 pounds more for the Grizzly. If that 5 pounds is in the form of more mass in the machine, that is a good thing. And that 5 pounds will cost about $30 more.
All that said, go back to the store. Extend the arm to its furthest. Bring the table within reach of the chuck near the end of its travel. Assess how much flex there is when the chuck meets the table with increasing pressure on your part. That will answer a lot of your questions. Obviously, it would be good to be able to do that to a machine of different manufacture.
One other thing. The majority of your drilling will be done with the arm retracted nearer to the post. If there is any flex there, that would be a deal killer. I thought long and hard before I replaced one radial arm drill press with another. That said, I am not unhappy with the Grizzly.
Hope this was helpful.
Jim DeLaney, Austintown, Ohio
>George,
Pay close attention to what Carol said. She's spot-on in her evaluation.
I have the Shop Fox radial press, which is a clone of the Grizzly, and I like it a lot. Like Carol, I seldom extend the arm, and the DP works just fine. On eh few occasions I have extended it, I did notice some flex, but not enough to be of great concern. As long as I know it's there, I can compensate for it...
One other concern arol didn't mention though, is that, when extended, the machine is very tippy unless you have it bolted to the floor. I have mine on a mobile stand, which is both longer and wider than the base, and have a small cabinet on top of that which has probably a hundres pounds of various other tools in it. This helps the 'tippy-ness' but doesn't eliminate it.
Bottom line - Would I buy this DP again? Yes I would! It gives me precision drilling capability that would be hard to achieve otherwise.
Jim D.
>Thanks, Jim, for pointing out the top heaviness and imbalance of this tool in the extended mode. I had forgotten, in that I have mine bolted to the floor.
When I had the benchtop, I built a roll-around cabinet with a large enough footprint to counteract these forces. Of course, I bolted the drill press to the cabinet top (2" thick). The upside was that I built drawers in the base and had extra storage.
about radials in general
Robin Corell in Atascadero CA
>I have a Unidrill which is a 1960 vintage delta radial that is very similar to the $625 radial that Grizzly sells. I seldom use the radial feature and prefer to make angled sub tables and find that they have several advantages. most important is that they are 100% repeatable. second is that when using a sug table I can move the drill head to any spot on the table and still be at the same angle. Whith a radial drill the angle is only acurate when the head is perpendicular to the table. As the head swings in a radius the angle becomes a compound angle. I like my radial for other reasons that are more particular to my machine than radials in general. I just wanted to point out that a radial drill is not necessary to making chairs and you may be better off to put the extra cost of a radial into a better standard DP.
Robin
Mike Jurnigan in Suffolk
>George,
I have the Craftsman version of the bench top model. I have noted some flex in the table when I was using the mortising attachment with this drill press. I installed some blocking underneath the table to counteract the flexing when I was using the mortising attachment.
Mike in Suffolk, VA
Thanks. Decided Against the HF Bec ause
>Good Morning Friends,
I appreciated everything you all said in the above posts. Carol, you gave me something to chew on when you quoted a weight differential between the Griz and the Central Mechinery machines. Upon further examination of the specs on respective web sites, I find that the HF is rated at 1/3rd hp @ a whimpy 3 amps. Further, the 5 speed range is more narrow than the Griz. My current drill press is 3/4hp and has a 12 speed range. I haven't needed need that power and capability in the ten years I've owned it. It is an AMT floor model. Still, a 3 amp replacement leaves me underwhelmed. I am also happy to know more about the stability issues. I'll need to use a mobile stand, lest the business end of the press goes the way of the grandmother clock bonnet. Robin, your comments are well noted. thank you.
George
