One More Tile Cutting Question
>Thanks for all that great advice below. Sorry, but I have one more question:
Let's say I have an outside corner that I need to wrap with ceramic tile. The tile in question does not have a bullnose trim. The edges therefore are raw. My guess is that I need to do bevel cuts?
Any chance that the $75 saws can do bevel cuts? Or are there solutions for those corners that I am overlooking?
Tom
Re: One More Tile Cutting Question
>Bevel as in blade tilt - nope. Bevel as it baby miter gauge? - Yes.
You can always try roughing it and then polishing it with a coarse diamond paddle. Or maybe you can do a jig. You do have two miter "slots" that you can use.
Ken Oakley-Sunny St. Cloud, Fla
>Might be cheaper to hire a tile setter rather than buying all kinds of doodads you will probably never use again.
How about...
>...a quarter round of some complementary tile or ceramic molding? A mitered corner is going to be beaucoup sharp even if you manage to cut the tiles accurately.
2 ¢,
How dare you.
Virgil
>Suggest getting a hired gun. Might as well buy your furniture from Wal-Mart too. :-) Why hire it done for 100 when you can do it yourself for 250.00.
Eddie Pacheco; San Jose, Ca.
>HD and possibly Lowe's has a white rectangular stone that is perfect for this. It costs about $2.00. HD also has some other inexpensive hand held coarse diamond grit tools that work wonders on breaking the sharp edges that result from cutting a tile piece.
These hand held tools won't exactly give you a factory rounded edge, but they do a heck of a job, nontheless.
Besides, it's not like you're going to have a tile expert visit your home to inspect the work. Look around at other commercial tile jobs and you'll see the short cuts right away.
Oh, the only reason I say "HD has" is that there isn't a Lowe's in my area yet. They broke ground on one about 2mi. away and it' supposed to be finished sometime next year.
Good Luck, Tom.
Kneale Brownson dreaming of snow in N. MI
>I have one of those sliding table tile saws. I made a 45-degree jig to ride on the table to make mitered cuts.
You do end with a pretty sharp edge that, if you round it with a diamond grit stone, loses the ceramic sheen. But if you leave a little gap and fill that with grout, you can help "ease" the edge.
Keith Newton
>You can get cheap diamond for a right angle grinder, to do some edge grinding.
Rather than thinking of a sharp OS miter corner, you would do well to grind the back corner, then have the grout out on the corner, across at a 45�.
For the base, I have seen the pros saw those large tiles up for base, then grout the tops to finish that raw edge there also, so think of the grout as the edge, rather than the tile nosing.
Fred Davis
>I don't know if your talking about a wall to floor tile or a tile corner on acabinet, but if the tile has no outside corner trim piece , take some tile to a tile shop and have them cut the tile with 22 1/2 bevels rather then 45's and then a narrow piece with a matching angle on each edge , we do that all the time with base board.
FredD
kirk constable
>My $80 HomeDepot wetsaw has a tilting table... FWIW.
how I did exactly what you are asking about
Robin Corell in Atascadero CA
>Tom, I'm not a tile setter and I don't play one on TV. I have done a total of two tile jobs one for my parents and one for my ex wife. Both parties were happy with the results and both jobs had exactly what you are asking about. On my parents the radius corner was on a breakfast bar counter and the tile was a bull nose. My parents decided that it would be cheaper to buy the cheap saw from HD than to rent one if the rental went for more than two days. It turned out to be a smart choice as I needed 2 1/2 days. The cheap saw was surprisingly accurate and will live to do my kitchen and bathroom as well as one more bathroom for my parents. Eddie is right about the saw blade not tilting. The saw has a miter gauge and it is serviceable even if it is a bit flimsy looking.
On the job for my ex wife the tile was not available in a bull nose. The tile was unglazed porcelain that was colored to look like honed slate. She bought some diamond polishing pads that are the same size and shape as a hand sanding block. I used a 4" dry diamond blade mounted on my angle grinder to freehand a 1/4 round on the edge and then polished it before cutting a 2" strip off to use in place of bull nose. I also rounded and polished the edge tile which gave everything a very nice look and feel. On the corner I used the wet saw that she rented and then used the hand held dry blade to grind a back bevel. You need to use the wet saw to give the edge a nice smooth cut because the dry blade can chip out the edge on the show side, or in wood terms results in tear out. Back to the cheap wet saw, the rip fence is really cheesy looking but it is actually holds well and if you measure front and back it is pretty accurate. On both corners I did not polish the edges of the cut pieces and they looked kind of scary until the grout. Speaking of grout you have to be careful to leave enough and if you do it like the field tiles you will pull of too much. You almost have to try and leave too much and then it turns out looking right.
And then there is grout the saving grace of amateur tile setters. Wide grout lines are easier than thin and sometimes those little spacers don't work as well as going by eye.
Have fun with it and keep reminding yourself how much you are saving.
Robin
Re: how I did exactly what you are asking about
>some of the small edge pieces can be difficult to hold in place with tape till the thinset sets up. On these I used a dab of hot bondo in the center and thinset on the edges as normal. the bondo goes off in a few minutes and holds things till the thinset sets. Six years and still no call backs so I guess it worked.
Robin
