>I am about to replace a 32" storm door on the side entrance to my brick house. I measured the rough opening at 31.75". I just received the Pella storm door and note that I need a 32.5" rough opening. I have plenty of wood on either side of the rough opening to take off 3/8ths inch but can't fit the narrow side of my circular saw up against the brick siding. I need a new tool to do this...honest.
I have a Panasonic 15v drill and am interested in buying the companion cordless saw if the "guide to blade" is narrow enough to snug up against the brick surrounding wood molding. Anybody know what the guide to blade distance is? I really don't want to tear this wood molding off, rip and reinstall.
How about a router, and a little hand/chisel work on the top and bottom? The router can rest on a full length temporary board and run against a simple cleat.
I think you missed the most important point here... The man desperately wants to buy a new tool! He can rationalize it. He can even justify it, which is more than most of us can say.
>Ralph, I have to agree with George in using the router. You probably will need to buy an extension for the router bits....like the use when turning bowls with a router. But you will end up with a very clean cut and the short ends can be taken care of with hand chisel and patience.
He's a lucky man. I've set him up to where he can buy the router and the cordless saw. Plus bits, and maybe some LV chisels besides. He dcan do one side with the router and the other side with the saw without getting in too much of a "jamb" with SWMBO. I wonder if a little Colt is strong enough to do the job.
>My little Colt would not be the router I'd use. I don't think it's up to it. Something more on the order of a PC69x series. A longer, 1/2" diameter upcut spiral bit, probably.
In fact, the little Colt doesn't get asked to do much at all any more here...
>If you don't already own a reciprocating saw, you should. There are lots of good ones; the Milwaukee Sawzall is the standard, and the one I chose to buy new after using a Makita for a long time. The basic cheap one (about $120, unless on sale) is all you need.
Or, depending on your situation, there's another type of cordless saw you could consider, link below. These can be acquired for not much money, and will do things that no other cordless saw can do, including helping you lose weight.
