HF 8" wet/dry grinder *LINK*
Dan Mitchell
>A few days ago, I picked up the Harbor Freight wet/dry grinder in the link below, after viewing the following Youtube videos on the machine: http://www.youtube.com/watch?v=zlrqzWU-StQ
http://www.youtube.com/watch?v=YqGo8PWr3Vk&feature=related (parents in the audience will love the ending on this one).
This grinder, which has a nice, quiet induction motor, is pretty much the same design as the Scheppach Tiger 2000. It has some fit/finish issues (there's a bit of slop in the plastic bushings for the support plate, and I'm not sure what the heck the factory used to tap the set screw sleeves where the tool support enters the machine) but after using it to sharpen 4 chisels & 2 plane blades, all to an arm-hair-shaving edge, I must say I'm very impressed with the final results. Apparently, jigs for the Scheppach, Jet, Grizzly and others may fit this machine (though I have not verified this). Next I may pick up their scissors jig, which looks like it may work with some nasty 8" jointer knives I happen to have on hand ;-)
The machine lists for $109.99, but of course, no one pays full price for HF. It's currently on sale at retail stores for $79.99, plus I had one of their ubiquitous 15% discount coupons, bringing the tab to $68.63, out the door. I'm sure it's no Tormek, but given the results, and that it costs about 1/10th the price, I'm extremely satisfied.
Dan
http://www.harborfreight.com/cpi/ctaf/displayitem.
Re: HF 8" wet/dry grinder *LINK*
>Thank you Dan,
Its great to have some competition to lower price and enhance quality for the masses. I have few HF tools, but what I have are well used and appreciated in my small shop. I need to visit the local store next week to get a couple items. I wanted to check out any polishijng heads they might have. My old Crapsman went South after 40 years. So you have given me another excuse. thanks.
George
David
>I hate to be the nay-sayer but I just bought, tried and returned one of these (69.99 manager's special price). I tried it on a couple of plane blades, which it did make very sharp, but they are also no longer square. Too much slop in the jig and in the wheel. Maybe it was the one I got but now I have three plane blades that range between 89 and 87 degrees :( Guess Stanley put the lateral adjustment lever there for a reason.
DGW
Dan Mitchell
>David - I think with most grinders, some dressing of the wheels is required to one degree or another. I had a diamond tool for this on hand which I used to true the wheel before use.
There is a fair amount of play in the plastic bushings on the support plate. I haven't seen one in person, but from the pictures I've seen online, the Scheppach fixture looks pretty much the same. I found that, by positioning the jig consistently on the shaft, I was able to get a true edge, but I'm going to try & come up with some type of plastic insert, maybe pvc or some other plumbing bit, to take the place of the present set of bushings and eliminate some or all of this slop.
I have a fairly wide range of tools, in terms of cost, and I tend to pick each based on likely need/level of service. While I have a number of HF items, I also have more high-end gear, such as a PM table saw & jointer. In the case of this sharpener, since my woodworking is primarily machine-based, I don't anticipate the frequency of use, or require the same durability someone might who worked primarily by hand. If I did more hand work, I'd probably look seriously at the Grizzly 10" wet grinder.
It seems to be an unfortunate fact that, regardless of the price, most woodworking equipment requires a fair amount of tuning/truing/tweaking to get the most out of it.
Dan
HF is maligned by many
Dan Mitchell
>but let's face it, every maker has produced some dogs. At least in the case of Harbor Freight, you're not out much if a tool turns out to be a dud ;-)
I tend to buy there stuff for applications I don't face too often, and/or those not requiring a great deal of precision. So far, I have been satisfied more often than not.
Dan
Re: HF is maligned by many
Doug Ridley
>I have never bought much from HF andwasn't thrilled with them but I recently bought a 23 gauge pinner from them for $25.00 and it seems to work great. I don't use it a lot and couldn't see spending hundreds.
Doug
David
>You're right, most machines require some tweeking to get them running the way they're supposed to.
I do buy the occasional thing beyond supplies from HF and know that I'm going to get what I pay for. I love the narrow crown stapler I got a year back. Has always worked reliably, as have hose reels and the like.
My beef with the grinder was the fit, the bushings as you point out are way too sloppy and I couldn't find a spot that would give me a perpendicular face. The other problem wasn't so much with the wheel as it was with the shaft having too much play where it comes out of the housing. Me thinks me got a lemon, and the last one on the shelf so I couldn't exchange and try again.
Just did 3 chef's knives
Dan Mitchell
>I can't get over how well & how quickly this machine put a fantastic edge on these knives. Unlike the chisels I did earlier, (a Craftsman set of 4 from the early '60's which belonged to my father, and which were pretty much screwdrivers when I started with them), these knives were in fairly decent shape, though pretty dull. Didn't take more than a few minutes each to get them frighteningly sharp. I worked in restaurants in my '20's, and I've use professionally sharpened kitchen knives, these came out as sharp as anything I've seen.
I'm one to bitch up a storm if something doesn't work as it should (just ask my wife, who has to live with it ;-) I really have to say, especially for what this machine cost, I am very impressed.
Dan
