Sanding hardwood floor questions?
>I have been sanding some oak flooring I patched in an old house I am working on. Using a Silver Line drum sander with an 8" wide drum about 6" in diameter. It has wheels in the back and the drum in the front. Tip it forward and it sands, tip it back and it lifts the drum. I have about pulled both arms out of the sockets fighting with this thing for two days.
Am I using the wrong technique? Can you describe a way that makes it both effective and easier? I have been hold the handle up and pulling back on it at the same time. It cuts more aggressively if I pull it backwards. Would it be better and easier to just restrain it and let it drag itself forward?
