Help with water base over oil
Jeff Grahn
>I coated a cabinet made out of birch ply with oil based stain and i want to put water based clear coat over top. I have done it before and I know that it works.
I wonder if there is a point where I put too many coats of oil based stain, the water base clear coat won't be able to stick to the surface?
Re: Help with water base over oil
Jason Roehl in Lafayette, IN
When in doubt...
>...put on a coat of de-waxed shellac before your waterborne finish. That, and increase your drying/curing time of the stain before the next step.
Jason
Robin Corell in Atascadero CA
>it is posible to paint waterbased finishes directly over wet oil BUT each combination of products must be tested together first. My favrite combination is waterbased General HF poly over Jasco tung oil.
I would probably test any waterbased finish over any dry oil product for adhesion as well.
Robin
