Hinge installation instructions
Bill Tindall, E.TN
>Proper hinge installation seems to be the bane of many woodworkers. I see a lot of crappy hinge installation, even on high dollar pieces.
1. Buy a quality hinge. I get mine from Whitechapel. They are the same kind as what Woodcraft sells. Select a hinge with a blade a bit less than the thickness of the box side. Hinges are sized by their open width.
2. Place the hinge on the box lid where you want it. The center of the hinge barrel should be located just outside of the lid edge such that about 1/3 of the barrel is buried in the mortise after installation. Scribe around the hinge with a marking knife, pocket knife, Exacto knife, etc. Scribing is the hardest part. The hinge must be square to the lid or the lid will set crooked on the box. To ensure alignment I use a marking gauge to mark the width of the mortise on the lid. The marking gauge gives me a perfectly straight line for the mortise width. If you are careful to get the hinge perfectly aligned you can skip the marking gauge and just scribe around the hinge after aligning it with a square. I have been known to clamp blocks to a piece to aid hinge alignment. I repeat, this is the critical part.
3. Remove waste from scribed mortise. I use a small router to remove most of the waste and a chisel to get up to the scribe line. The depth of this mortise is a tiny bit less than one half the hinge barrel thickness. If the mortise is too shallow the lid will sit proud of the box. If too deep the hinge will bind. I use a practice piece to get the depth just right.
4. Install hinge on the lid. Ideally it should press fit into the mortise with zero gap showing. (Advance technique. I file a tiny chamfer on the hinge plate bottom before scribing so the scribe line will be a few thousandths inside the actual hinge width and length. Hinges fit tighter in mortise by doing this step) I use Vix bits for drilling holes. If the hinge sits tightly in the mortise it will not move out of alignment when drilling holes. If using brass screws first establish screw holes with a strong steel screw. I use a test block of the same wood to get the pilot hole size perfect.
5. Align lid on box and mark hinge location with a knife mark. Scribe and make mortise on box as was done for the lid.
I suggest practicing before doing the finished box.
