dovetails on long grain
David
>I'm building a couple of small drawers (approx. 11" wide x 4" high x 8" deep) for small parts, block planes, and the like. I intended to use spalted sugar maple for the drawer fronts and join the sides with half-blind dovetails. The catch is the grain direction of the maple, i.e., the grain runs vertically (the 4" dimension) rather than across the face. Will I be wasting my time to try and cut dovetails in long grain? Would I be better off hand chopping than relying on my Leigh? Should I use a different kind of joint? Or should I just get a different piece of wood? Thanks!
Re: dovetails on long grain
Glenn Madsen near San Francisco
>I think a different type of joint is in order here. A sliding dovetail, perhaps, or something similar. Maybe a pinned rabbet joint. Really depends on the overall design of the piece.
But cutting dovetails so that the grain goes across the pins is a recipe for disappointment as often as not. Certainly it isn't the way they draw it up in the instruction books...
wilbur
>Dd you consider making a drawer, and then just attaching the spalted maple to the front side of the box?
David
>I was thinking that a rabbet joint of some sort, the less complicated the better might be the way to go. Pinned rabbet can even look good.
Hadn't thought about adding the maple after building the drawer... good idea!
Wilbur Has It
>Good Morning David,
I also would mechanically apply the drawer fronts to the dovetailed boxes. You get the strength and beauty, and don't risk grain problems cutting dovetails. You may even be able to resaw the drawer fronts and double the stock's yield without any compromise at all.
George
Half blinds would be OK...I think
Re: Half blinds would be OK...I think
>It really won't make any difference on the size drawer you're talking about whether they are exposed or half blind. Seasonal movement may open the joints a couple thousandths, but you can always pin a tail or two to the face. It ain't gonna come apart.
Clint
David
>Just thought I'd let y'all know, I went with Wilbur and the Colonel's suggestion and applied the spalted maple fronts after the fact.
Thanks!
drawer front
David
wilbur
>Nice job! It looks like you cut those dovetails right into the spalted maple. I bet the only way you could tell that the drawer fronts are attached after the fact is by looking closely at the grain.
David
>Thanks. I guess the glue that seeped into the end grain of the pine sides helped disguise them :-(
NICE!
