Unisaw motor hums but doesn't start
Rick Cansler
>I have a 3hp Unisaw that suddenly stopped working. When I push the switch to start, I hear the motor humming, but the motor doesn't start rotating. I can easily rotate blade by hand and see the belts rotating the motor pulley. Any ideas on what the problem is and what I would need to do in order to get saw working again?
Re: Unisaw motor hums but doesn't start
>Sounds like your start capacitor has failed or possibly your Start switch. (not the right name, but I am having a senior moment.) If the motor Is "Open", you might be able to blow it out and get the dust out of the contacts of the starting switch. You might have to take the end off the motor and clean the contacts or pry them apart if they are stuck/welded. If they are you can polish them with some really fine sandpaper, Maybe 400 grit. This is the centrifugal switch that help boost the motor until the shaft reaches a certain speed. If none of this makes any sense to you in spite of my poor description, maybe you should take it to a motor shop for evaluation and repair. Be sure to unplug it any time you work on it. Replacing the start capacitor is fairly easy.
Ken Oakley-Sunny St. Cloud, Fla
>Sounds to me like a bad start capacitor. Also check if the shaft on the motor is turning but the pulley isn't. The key in the slot on the shaft may have loosened and be laying in the sawdust inside your saw. Happened to me once. Found key, put it back in slot and been working ever since
Alan in Little Washington (NC)
>Barry is right on, or it doesn't know the words?
More help Re: Unisaw motor hums but doesn't start
Rick Cansler
>I took one end cover off motor ( opposite pulley) and found just fan. There is another cover on the same end that is held by two nuts that come out from parallel to the motor. I didn't want to tackle taking these nuts off without checking to see if this is correct.
Note- I have a Unisaw that was built I think in the '80's model 34-802f
Sounds like my first wife
Larry in NW Ohio
>Another possibility, if you is wired for 220 volt, one half of it may be bad, as in the contact in the starter switch may have enough sawdust in and not letting the contacts make a good connection or they may be burnt and stuck together. Also when you took the end of the motor off all you were doing is getting access to the fan as you saw, no pun inteded. What you saw, there we go again, was the cooling fan. When you take off the next part you`ll start to get in to the heart of the motor, the armature. Everything for the motor is in there, But the first thing I would look at after pulling the plug is the starter switch and blow some air in there and check the contacts. Good luck Larry in Ohio
Maybe it doesn't know the words.
Forrest Addy
>seriously sounds like capacitor. Common problem on single phase motors. Easy to fix. Replace the caps.
The Capacitor is not inside the motor
Keith Newton, LR, Arkansas------WebKitFormBoundary
>It is usually on the outside, and is about 1 1/2" D x 3" L.
Be careful when you disconnect the wires not to short them, even when the power is off.
Rick Cansler
>Just want to check that the starter switch that I am looking will be found behind the rear cover of the motor. Correct?
Rick Cansler
>Disregard post on switch- dah!- I know where the starter switch is. Thanks for responses.
John Veerkamp, Western Mo
>Make sure you still have 220 at the saw. If one leg of the 220 is out , this is exactly what happens.
John
Solved Re: Unisaw motor hums but doesn't start
Rick Cansler
>Took cover off box on Unisaw were electrical wires come in and blew air all around. This solved problem and saw started mormally. Thanks for all the responses.
Re: Solved Re: Unisaw motor hums but doesn't start
Chuck in ND
>Why manufacturers put an electrical box and or switch inside a dust producing cabinet is beyond me, they do the same thing on Contractor saws. I relocated mine and mounted it under the fence where it really belongs, out of the majority of the dust and easier to reach.
