Re: My New Oneida 3hp Gorilla
John in Calgary
>To address the start/stop question - the killer of any motor is degradation of the insulation on the windings. The insulation self destructs with heat, but its not just a maximum temperature relationship, usually its a time/temperature thing that is cumulative over the life of the motor. The more you run the motor overloaded, or the more times you start the motor, the more heat damage you get. The only thing you can qualitatively say is that the higher the current flowing through the motor, the greater the damage, the shorter the motor's life. So what does that mean to your average hobbiest? Well, maybe your motor will only last 10 years instead of 20, or maybe its 15, or, well, its hard to predict.
During start-up, the motor will usually draw 6-8 times its normal operating amperage, which means a large heat load. Every time you start the motor, it goes through this cycle. If you start & stop the motor many times in a row (i.e. 6 times per hour as mentioned by Joanna above), you don't give the windings enough time to cool down from the high starting temperatures, so your next start begins at an even higher temperature, resulting in greater damage to the insulation.
So can you predict the longevity of your motor based on how you use it? No, its kind of like smoking, the long term cumulative effects are too hard to pin back to any one operating scenario (in other words, there is no way you are going to be able to say that it was that day in September 2008 that really sent your motor to its early grave).
John
