Have a question? Ask Woody!
Motor wiring revist
Motor wiring revist
Motor wiring revist
Larry in NW Ohio
>I tried to figure out what Dan and Keith reply to my post the other day, and I just can`t see it yet, must be all the meds. I`ll put the schematic up again and explain it a little better. Please be a little patient with me, I have a hard time trying to explain things.
The motor is a capacitor start with only 4 wires, the 2 incoming wires and A&B. I`m assuming I would use the Induct. Repulsion schematic in the bottom right corner. Can someone tell me which wire is which? Like which wire is A&B and where do they go, on3&4 and the incoming power go on 2&6. Or do you use the 3 leads single phase schematic and the wires go on #2 with the common incoming wire and A&B on3&4 and the hot incoming wire on 6? I`m sorry to be so long winded but I try to be as clear as I can. Thanks again Larry in Ohio
Re: Motor wiring revist
Larry in NW Ohio
>Of course I for got to explain something. In the top right corner is what the inside of the motor looks like. only 4 main wires, 2 incoming and 2 that are in the motor. Thanks again Larry
>Larry, are you trying to set up a reversing switch. Not clear from this message.
I think I can explain it if that is your goal.
You need a double pole double throw switch. (DPDT) Rated for whatever amps the motor pulls.
Now for the hard part for me. The switch will have three terminals on each side. Think of them as ABC down the left side and DEF down the right side. Using jumper wires suitable for the amps, connect 1 to A, 3 to B, and 5 to C. On the other side, Connect 6 to D, 4 to E, and 2 to F.
If you think this through you will see that the switch now does what the diagram does, because we interchanged the position of 2 and 6.
If this is not what you were asking, NEVER MIND! Maybe I should have read the other responses.
Larry in NW Ohio
>I posted the the original on Sat the 13th. I didn`t explain it very good. It`s going to be a reversing barrel switch. I`ve just been away from wiring just to long and forgot a lot of things. I know the answer is right in front of me but just can`t see it. Larry in Ohio
Keith Newton, LR, Arkansas------WebKitFormBoundary
>Larry, I thought I understood what you wanted to know by what was under the heading for the switch.
Where did you get the information to the right in the diagram. Is this off of the motor plate, or from somewhere else?
Could you photograph the information plate from the motor, and also showing the wires when you remove the cover plate?
If you have been using this motor, you don't need to change where the leads come into the motor, that is already worked out for you.
As for choosing between 110 and 220, use whatever you already have.
Usually the motor plate will say something like change 5 & 8 to reverse rotation. and those are usually shown tied into groups of wires tied together. That is all of the information needed.
This switch doesn't replace the on- off switch. Bt you probably already knew that.
Also, I should mention that all motors can't be reversed.
Larry in NW Ohio
>Keith Everything you see in the picture, except in the upper right hand corner comes off the Barrel switch. Where it says Drill motor in the upper right hand corner comes from the motor plate. As you can see there are onlt 4 wires in the motor and the motor says "to reverse the motor change the A&B wires. What diagram do you think should be used, the three or four wire. Or a different one.Thank You Larry in Ohio
>Larry, If you have been using this drill-press, and it runs, forget about those wiring diagrams. You don't need to know or understand anything about that. All you need to know is that it works, and to change it will probably be a mistake.
Now,,,,,,,,,,,,, If the motor says to reverse, to swap A and B, this is all you need to know.
In the reversing switch. you should connect A and B to one side of the switch. Then to the other two screws on the other side of the switch. hook whatever they are connected to now.
If they are under a screw or other fittings. Just make a jumper wire to get connected to the other two screws of the switch.
The reversing switch will either carry the current across as it is now, or will cross the wires, connecting them to the other side. that is all there is to it.
I hope that helps. If not, you need to post photos, because your drawings still leave everyone lost for information to really help.
Larry in NW Ohio
>Thanks Keith I knew it was right in front of my face, but it just didn`t register. When I get a little time I`ll play with it. Larry in Ohio
