>One half of Our house is built on a basement and the other hale has a crawl space, and that would never happen again. Anyway in our upstairs wall where the two join, we get the fabled wall crack and when we have drought conditions it gets bigger and closes a little when it rains. Is there some way to cover this for good. I`ve tried the tape and the joint compound, but the tape only strechs so far. Anyone have any ideas? Thank You. Larry in Ohio
>They used to have a flexible fiberglass mesh kit. It was called "Tuff-Patch" and it was made by Synko. It worked reasonably well and was somewhat flexible. There have been similar sorts of products.
>I can't help with how to repair the cracks but we do have the cracking wall problem in this part of the country. One way to reduce if not solve the movement issue is to use soaker hoses around the foundation. Keeping the soil more or less consistent will help prevent the expansion and then contracting.
