OT - chainsaw issues
>I've got a Poulan chainsaw that's got a running problem. Starts fine, runs fine as long as it's running fast, but, when I let it idle, it slows down over 15 seconds or so and then dies. I'm thinking it's a carb adjustment (lean at idle?), but know very little about these carburetors. Any thoughts will help.
Re: OT - chainsaw issues
Robin Corell in Atascadero CA
>Chainsaw carbs are very simple as far as carbs go. You should be able to find an initial setting for the air mixture screws in your owners manual or a manual for the carb. Do a google search for the maker of the carb, many manufacurers have service instructions available as free PDF downloads.
While I am a big fan of learning and teaching how to work on equipment, an incorect carb adjustment on a cahinsaw can burn the saw up in less than 5 minutes. I would recomend only working on the saw within the specifications of a manual or service manual rather than seat of the pants or intenet advice of "tuning by ear". Once you have a refrence point for a correct running carb tunning by ear can be very effective, but it is not a good starting point for a poor running saw and a begginner.
Try searching the archives over at arboristsite.com Their chainsaw forum is near the bottom of the forum links page.
Robin
Ken Oakley-Sunny St. Cloud, Fla
>I had a Poulan and found if you don't clean the air filter sponge on the carb the saw just doesn't run right. It is a $1.50 item if you can find someone who carries them.
Re: OT - chainsaw dies
Al Stokka - Cambridge, Iowa
>Bill,
Classic symtoms of a dirty fuel filter (on the end of a flexible tube in the fuel tank).
Al
Tom Dunlap
>If you have one of the Poulan Wild Thing saws you'll find that they don't last long. On a couple of chainsaw forums they're refered to as a 'shortlife saw' Could be ten hours could be fifty. They die young adn aren't worth repairing.
tuning is another matter.
Look at the carb and find out where the fuel line enters. One of the sides, it will likely have one screw in the center. You may be able to take that side off without removing the carb from the head. If you do have to remove it be careful not to tear the gasket. Have a razor blade handy to cut/scrape the gasket and keep it in one piece.
Once you have the side of the carb off look at the orifice where the fuel line enters. You'll find a shallow pocket with a super fine screen filter pressed down into the pocket. Carefully pick out the shavings. You can use a VERY GENTLE spoosh of compressed air to clean out the remains.
Try that before you change carb setting. If the saw still bogs you may have to readjust. It sounds like the Low needs to be opened up just a little. When I adjust carbs I turn the screw in increments of one slot width. Make the adjustment and then pop the throttle a few times. To find out how to tune a saw you can google something, there are lots of really good websites with instructions.
Let us know how the tuning turns out.
>I bought my Wildthing in the early 90's and it sure got a workout during Hurricanes Charley, Frances and Jeanne plus years of cutting up logs for my use. When I was given a Stihl recently, I gave it to my neighbor. It still performs great
Tom Dunlap
>ken,
You must have gotten one of the 'defective' Wild Things...the one that lasts :)
Don't get me wrong...I'm an arborist and have used chainsaws for close to 40 years. For MANY years I ran Poulans...but now they have downgraded the quality and they are like McCullochs...not worth much. Better off getting a consumer grade Husky. They're worth fixing.
