Twisted panels
Twisted panels
Twisted panels
Rob Scrimgeour
>I have just made 6 cupboard doors, 8' x 1' 3", from commercial 3/4" laminated pine wood panels, and on hanging the doors I find that they all have a slight but uniform twist - the panels were purchased by the client about 4 weeks ago, and I have no idea if the twist has been introduced by bad storage, or if it came from the supplier that way. I have experimentally attempted to rectify one of the doors by clamping an opposite twist in it, and although it initially seemed to work, it eventually returned to its earlier bad state. Is there a trick to this? i.e. possibly wetting the wood while clamping? or should I consider this a write-off? Thanks for any help.
Rob in Wilderness, S.Africa
Re: Twisted panels
Re: Twisted panels
Lee Brubaker
>Rob: They likely came from the supplier that way if these were laminated pine panels encased in clear plastic. If so the twist likely occured due to high moisture content when plastic wrapped then improperly stored by the retailer by standing them on end & slanted to keep them from falling out of the racking. They should have been stored flat & the wrapping should have "vent" holes to allow the panels to breathe. I don't know why they would plastic wrap the panels because it is certainly not going to protect them from rough handling.
I know of no way to take that twist out.
Lee
Re: Twisted panels
Re: Twisted panels
slashdev
>There are a couple of ways to do this, but it takes a little thought, and hand tool skills would help... It involves inserting some "corrective" pieces in the face frame. If it's painted, you don't have to be as careful. If it's a clear finish, you'll want to be a little picky about the extra stock. With all that said, here's what you can do:
First, figure out which frame member(s) is(are) bowed. I suppose that if the panel has warped, all of them *might* have a little bow. Pick one to straighten.
One technique that can fix a bow that is concave or convex is to route a deep groove in the edge, but not all the way to the panel groove. Glue in a matching stick and straighten while clamping. You might want to over-straighten a hair if you think it's going to spring back after you unclamp it.
I've done this on a solid interior pine door and it worked great. The patch was on the hinge side, so you'll hardly ever see it. You could also insert a strip on the back face, but you almost certainly have to plan for spring back.
A second technique that can only fix concave bows is to insert a cross-grain wedge in the member. Cut a tapered dovetail recess (cross grain), about as deep as the panel groove. It can be as little as 1/4" wide, but 3/4" to 2" is better if it's cross grain. It needs to be at least as deep as 1/3 to 1/4 the thickness of the member (probably 1/4"). The taper should be about 1/16" to 1/8" per inch.
Prepare the matching wedge, which can also be cross grain. Make the wedge a little long so you can drive it in tight, but not into the panel. Test the fit, apply some glue and drive in the wedge. Flex the member a little, and check its straightness as you go. After it dries a little, trim the wedge up.
I've used this technique on the back side of door jambs that had warped, so the patches weren't visible.
Since the doors are 8' tall, you might put three or four along a stile. I would think one would be fine for a rail, maybe two.
I think the second way is a little fussier, and is more obvious when the door is open. With either technique, you can always try again by offsetting the groove or enlarging the DT recess.
Good Luck!
Re: Twisted panels
Re: Twisted panels
Rob Scrimgeour
>Thanks Lee - that exactly describes how the panels were wrapped and stored. I'm going to advise my clients to use them as shelving, and we'll make proper doors. Rob
Re: Twisted panels
Re: Twisted panels
Rob Scrimgeour
>Thanks for your input - I don't think I explained very well, as the doors are solid laminations, and do not have separate panels. But I have noted your advice with interest, and have filed away for future reference. Rob
Re: Twisted panels
Re: Twisted panels
Keith Newton, LR, Arkansas------WebKitFormBoundary
>Lee, I think it might be a good idea to do a little research.
Since most warping, or changing in wood is due to change in MC, the best thing a supplier can do is to wrap it in plastic to keep it at the KD desired MC.
Twist in a panel which has some wood from a tree which had a spiral grain, which is not that uncommon, would develop twist with a change in MC.
Also some plain sawn boards which were sawn where the pith slants across the face, rather than parallel to the edges can also twist with a change in MC. It would be easier to diagnose with some good photos.
