PC Nailer
PC Nailer
PC Nailer
Larry in NW Ohio
>I have a couple WW questions also. A couple of weeks ago I asked about a SENCO nailer, but since I have found out it`s a PC nailer, a #BN200V12.It`s a cordless brad nailer that has a small compressor in it run by a 12V battery. I`ve always been courious about this gun. Does anyone have one of these and how do you like it. I`d like to find one, but don`t see them anymore. I`m trying EBAY, but just starting. Anyone know someplace that may have them.
Also we just bought some 3/4" wood flooring that needs to be nailed. Sounds like a job for "NEW TOOLS". What has you used to put it down and any other suggestions that would help. Thaks to any and all suggestions. Larry in Ohio
Re: PC Nailer
Re: PC Nailer
Sawman
>For the new flooring project I would rent an air powered flooring stapler. They shoot 2"+ staples and really hold well.
Re: PC Nailer
Re: PC Nailer
>Larry, I think I posted on this before. My friend did not have one, but I have seen one somewhere and the guy that had it liked it for what it was. It was slow, you had to wait a few seconds between shots for the tiny compressor to run and pressurize it, maybe ten or twenty seconds. But for a gun to carry to a job site and not to have a compressor, it was good. He had other tools that used the same batteries and charger and was pleased with that. Just wish I knew who it was and where, but as an Inspector, I visit a lot of sites and they run together.
I have a big Senco stapler that will shoot the heavier (Q) gauge staples up to 2 1/2" long. Now that I don't build houses for a living I seldom use it. When I needed to lay flooring, I modified it to do the job. Ground the "snoot" to a ninety degree angle that would nest right into the corner of the flooring at the tongue. I sued it to nail a room of 3/4" oak. A little tedious, but it worked perfectly. Loaned it to a friend and he fabricated a shoe for it that held it at the correct angle. Easy to do and a big improvement. He was pleased with it too. The modification or the snoot did not seem to matter for regular use. So, if you already have a half inch crown stapler, you can make it work. If you don't have one handy, rent the floor nailer.
Re: PC Nailer
Re: PC Nailer
Fred Davis
>Barry's using a Senco staple gun to blind nail flooring was what I used to do when my knees could stand the pain, with one important additional step.
I used "K"model Senco guns shooting 1 1/4 " staples to blind nail the flooring while the PL500 or PL400 glue I used on the back of the flooring set up.
This operation insures that the flooring forms a mechanical and chemical bond to the subfloor making it squeak proof.
While it takes a bit longer to do this , it takes a lot longer to locate squeaks and try to eliminate them with wedges and cussing , throw rugs etc.
This is done for the same reason good construction practices include gluing the subfloor to the joists.
Nailing without gluing guarantees squeaks, gluing guarantees no squeaks.
FredD
Re: PC Nailer
Re: Second This
Kneale Brownson dreaming of snow in N. MI
>The purpose-intended flooring nailers or staplers are operated by hitting the top with a mallet. That process assures the flooring is pushed as close as possible to the piece that's already down. Using a standard nailer eliminates the extra little push of the new piece's groove onto the tongue of the fixed piece.
Re: PC Nailer
Re: PC Nailer *LINK*
Andy Lincoln,in Dearborn,MI
>Larry,
I can't help much on the portable aniler but for putting down a hardwood floor the Harbor Freight Floor Stapler can't be beat.
Unless you have a really good deal on a rental this one will pay for itself in just a few days.
Andy
Flooring Stapler
Re: PC Nailer
I have had good luck with Harbor Frieght
Dustmaker Mike
>tools. I am getting ready to buy a flooring nailer from them to do my dinning room. If it takes me two weeks to get it done I don't have to worry about the rental return, and I can do as much or as little at a time. I have a few of there toss away tools that are still going strong. They run these on sale at least every other month just sign up for there E-mails and you will get the coupons as well as 10 to 15% off coupons. Good Luck
Re: PC Nailer
Re: I have had good luck with Harbor Frieght
>Also they offer an extended warranty on most of thier products,I can't say for sure on the floor nailer but it seems to only be about $7/per tool for 2 years worth of warranty.I have yet to need to use thier warranties but $7 sounds like a cheap peace of mind to replace a $150 tool.
Andy
Re: PC Nailer
Re: PC Nailer
>Knew several guys who bought them for trim work, but went back to their Paslode Impulse guns because the PCs were too slow and somewhat picky about hard woods.
Maybe that's why PC stopped making them.
Re: PC Nailer
Re: PC Nailer
Vincent - Azle, Texas
>Larry,
I have the PC nailer and like it. It is good for soft woods and small projects. Critisims: It is slow, a couple of seconds between nails. It doesn't do as well in hardwoods. I have had brads just fold up with about 1/3 - 1/4 of the brad exposed when nailing Bz. Cherry trim. The battery doesn't seem to last long between charges, I'd get two so as to keep one on the charger.
I also had, has since been stolen, a Dewalt 18v cordless nailer. It ran me just over $200 on ebay and I liked it alot better. It is faster and has a rapid shoot feature that I likeed a lot when nailing trim. I don't think I ever had a nail fold and seems to me that I had less problems with the nails going sideways. But that could have just been technique. And the batteries last longer.
Also, I agree with the other guys about the proper nailer for wood flooring. That hammer activated nailer is the way to go. And glueing is worth the time, effort and expense. I hate squeky floors.
Good luck.
