Mahogany stain?
Bill Tindall, E.TN
>Does anyone have a favorite stain for reproduction work in mahogany?
Mahogany stain?
Bill Tindall, E.TN
Experiment
>"Reproduction work," to me, says deep reddish brown color with more-or-less filled pores. If I were trying to recreate a period piece, I'd consider a coat of a dye or NGR stain followed in due time by a pigment stain. I've found that it is only rarely that stain from a can will produce a color/patina that is pleasing or authentic-looking.
Re: Mahogany stain?
Robin Corell in Atascadero CA
>Potassium dichromate in a solution of a 1 teaspoon/pint of distilled water will accelerate the natural oxidation of mahogany. you can increase or decrease the mixture to suit your taste. the color can take a few minets to develope and is harder to control than a dye or stain. Potassium dichromate can really iritate your skin and they dry powder is a bit hazardous if inhaled.
Robin
Re: Mahogany stain?
Vincent - Azle, Texas
>Will direct sunlight do the same? Or will it bleach the wood?
I've seen sunlight darken Bz. Cherry significantly in a day or two. I left a bundle on the tailgait of my pick up, the exposed 6 in of one board half way down the stack was much darker than the rest of that same board. And dam*d hard to sand out too.
Re: Mahogany stain?
Tony - Memphis
>I use water based dyes from Lockwood. I get them from Lee Valley. I don't have the names with me, but I can look them up at home. If I look at their web site, I can find them. Anyway, I start with a deep dark red and follow up with a dark brown (has some red in it). After that, it's shellac, or whatever your favorite finish is. Careful with end grain. I almost always end up getting it too dark. I still haven't mastered staining/finishing cabriole legs. I need to make some samples and experiment. Some folks have suggested wash coats, but I haven't tried that. With my stain routine, the the first coat of the red scares you (its pretty red), but the brown coat looks great wet. Then, when it dries, it scares you again! One thing I learned is not to use oil over this. It just darkens things up and didn't offer any benefit that I could tell.
How is your class project coming along? I'm anxious to see it and hear more about the class.
Tony
PS
Tony - Memphis
>One nice thing about the water based dye is that you can vary the strength. I start out pretty light to see how this particular wood will take the stain. Easy to darken it up, not so easy to lighten it up!
Not a great pic, but you get an idea of the color...
Re: Mahogany stain?
Steve Schoene
>Here is a schedule I've used a couple of times. It gives a brown mahogany, with a little bit of golden highlights, which I think of mostly for the 18th c. period. I think darker red when moving a bit later, as into Duncan Phyfe. Work out on samples before doing the first thing to the project itself.
I start with a lemon yellow water soluble dye. This will look awful when dried--subsequent steps will convert yellow to gold. I then apply an approximately 1 lb. cut wash coat of shellac. This will seal only the densest of the mahogany. It still will look miserable. I do take care that after applying the dye I do give a wipe down with a dry cloth to pick up dye that has stayed on the surface so it doesn't lift into the next material. If I wanted a red mahogany this initial dye step could be red instead of yellow.
Next is another dye step, this time using a brown mahogany dye. This is one place to adjust the overall color. The densest parts will have been sealed in the prior step and the dye won't take very much leaving the gold to shine through a bit. The two dye steps create a bit of figure on otherwise boring mahogany. Don't judge whether it is just "blotchy" until you are done.
Another coat of 1 lb. cut shellac comes next.
This can be followed by either a pigment only stain, or a tinted pore filler depending on the look. The museum pieces almost always have a fully filled (or almost fully filled) surface. I like Behlen Pore O Pak. I buy the neutral and tint with either dry pigment or artists' oil paint. A mix of burnt sienna (reddish) or burnt umber (brown). After waiting a week for the pore filler to cure, I go to the top coats.
I finish with top coats of shellac, either brushed, padded, or possibly sprayed. The choice of color for the shellac makes a difference as to how "toned down" or not the figure created in the two dye steps.
not just a bit hazardous
Bill Tindall, E.TN
>It is one of the few proven carcinogens if inhaled.
that was most helpful
Bill Tindall, E.TN
>Another period maker suggested the beginning step of yellow also. So in spite of my reluctance to try it I am now convinced.
Re: that was most helpful
Steve Schoene
>You don't have to be convinced yet. I still recommend the sample board--large enough to see what is happening to "figure". Having done that, and tinkered with the mix, etc. really adds confidence to finishing the project itself.
Herb Yost
>As luck would have it, I'm taking a class on Finishing at the Center for Furniture Craftsmanship in Maine. Instructor is Teri Masaschi. That first coat of lemon yellow dye is exactly what we started with. It's so counter-intuitive...but when we follow through with the wash coats and the other dyes and fillers, the result is stunning....and this before the topcoats!
Yellow dye
David Yoho
>It's my understanding that starting with a yellow dye does something else that folks may not be aware of. I've seen times during construction where some of the wood (cherry and mahogany for sure) is darker than other pieces being used in the project. Even though we're supposed to select lumber from the same batch and match grain and color carefully, sometimes this is not always possible. The solution is to start the finishing process with a yellow dye. This will blend the dark and light pieces to end up looking the same. I'm sorry I can't give you all the technical details of why but I can tell you from experience it works.
David
sage advice indeed
Bill Tindall, E.TN
>I never experiment with a finish on a final product. I saved all the veneer trimmings to see how the finish would behave on veneer as well as the solid wood.
Gotta try this....
Tony - Memphis
>Mahogany is one of the woods I use the most. although maybe not anymore since it is getting hard to find and expensive. I'm anxious to try the yellow thing. I'm pretty happy with my technique, but this might be better. Need to order some lemon yellow!
Tony
