I acquired a free well used 690 router which has recently developed bad bearings. Enroute home, I stopped by the DeWalt/P+C Service Center who confirmed my diagnosis. They quoted me a price of $60 to replace the bearings. While I wanted the thing to give to my #1 or #3 son, I can still use the base and collets. I wonder if the bearings can be installed fairly easily by someone who is not a router mechanic. Has anybody done that job themselves, and what would you advise?
>George, I don't won that router, but I have replaced bearings in many of my other tools and it was fairly easy. My bet it it was about $10 for the bearings and $50 labor. Locally, there is a bearing "house" I go to and get the bearings and they are often better than the originals. I would tell you who they are, but you ain't from round here, are Ya?
I would certainly take a whack at replacing them. Spread a nice piece of cloth on your TS sort of like a table cloth. Take the router apart and pull the bearings. Buy new matching bearings and install them and assemble in reverse order. If this does not go well, lift the four corners of the cloth, tying them into a sack to confine all the parts, and you can take it to the repair shop and pay them the fifty bucks.
I went to the Delta/Porter Cable site and checked out Service Net. What a night mare. A horrible website. In one place it wanted my phone number as xxx-xxx-xxxx and in another as (xxx) xxx-xxxx. Would not let me proceed until I got both right. I also caught it changing the "Would you like product updates" form NO to Yes. Won't be going back to that.
>Colonel I`ve changed bottom bearings in 2 of my routers. One was a PC and the other a milwaukee. I can`t understand why they put low speed bearings in them, I think they were only rated 3600rpm. Like bary said they are only about 10-15 dollars. While your at it check the top bearing also. Believe me it`s an easy job. I did it and I only made PFC. (:-))) Larry in Ohio
I figured it would be easy. I thought maybe I'd open up the motor to see how it looked before ordering parts. Here I find that the casting the plastic top attaches to was missing a securing machine screw. I removed the sole remaining screw and saw that it it taps a aluminum casting which bridges over the top of the armature/bearing seat. The trouble is that the cast is broken and missing on the side of the missing screw. My guess is that the upper bearing can't seat properly as a result. And therefore without a new casting (which is the upper motor housing) new bearings would be ineffective in solving the root problem. The motor still works, and screeches when nearly almost wound down to a stop. So I'll keep the router and keep looking for one or two others to give the boys. I installed the router motor in my P+C plunge base, which I've seldome used. The base is fine, and I've updated one of my other router motors with the newer clamp height adjustment found on the current 690 models. Okay for a free tool.
