Bandsaw Tires
Bandsaw Tires
Bandsaw Tires
Jim Hoeller
>I was given a Jim Vaughan band saw that is quite old and made for meat cutting. Some time in its life it was converted to wood cutting. When I picked it up, it had a relatively new 2hp motor and needed tires. I thought it would be fairly easy to find a set. Unfortunately, it has 13" wheels and tires for a 14" saw don't work. Carter doesn't make any for that size and will not reveal the method used to join the ends of their 14" tires. I have not been able to find any on the web.
If anyone out there knows of a source, I would like to hear from them.
Thanks
Jim Hoeller
Re: Bandsaw Tires
Re: Bandsaw Tires
Gerry Wittenberg
>Jim, you don't mention which side of the border you live on so I'll give you two outfits that may be able to help. Google "Tufftooth" on the north side and Suffolk Machine should be able to help on the south side. Good Luck with your search, new tires sure perked up my old saw.
Re: Bandsaw Tires
Re: Bandsaw Tires
Galen V
>If it comes down to cutting a tire down: we made custom gear drive that had o-ring and flat belt type nitrile seals. Both were joined with CA glue. We made a mistake on the flat belt and cut at shallow 30 degree but CA glue is stonger in tension than shear and the cut put it in shear as well as tension. Went back to clean 90 degree. Since these seals were about 36" diameter were probably not under as much tension to slip into place as a 13". Hope you can find right part or someone to confirm how they factory join.
Re: Bandsaw Tires
Re: Bandsaw Tires
Larry in NW Ohio
>Jim There is a guy that builds bandsaws that posts here every once in awhile. He should know what you can do or where to go to find one. I tried to find he name, but no luck. Maybe someone else remembers. Larry in Ohio
Re: Bandsaw Tires
Re: Bandsaw Tires
Lee Schierer - McKean, PA
>Typically, meat cutting saws do not have tires, so you may have a problem finding them off the shelf.
Lee
Re: Bandsaw Tires
Re: Bandsaw Tires
William H. Falberg
>I get my band saw tires from Suffolk Machine custom made for 1" x 10" wheels but 13" shouldn't be a problem. Just ask..800-234-7297
