Marc's Shop
Marc's Shop
Marc's Shop
Marc
>Hi Everyone,
I have frequently lurked, and on a couple of occasions, contributed. I thought I would share some pics of my way-to-small garage shop, and some projects.
Here is the shop, which contains the basics. Although I have most power tools, over the past five years, I have really started to appreciate hand tools, so I finally had to make a real workbench, which is also shown.
(First time uploading pictures, so I hope there are no problems...)
Thanks,
Marc
First Pic is entering from the house. Straight ahead is the tablesaw. Almost all the walls are pegboard, which provides me with flexible storage, you can see clamps, blades, etc on the right wall. Further down from the TS, you can see the outfeed, SCMS. Far off in the corner is a lathe and router table.
Re: Marc's Shop
Re: Marc's Shop
Marc
>Here is the opposite wall. You can see the DC ductwork, which is 6" drain pipe. Also, the drill press, bandsaw, and drum sander. I should point out that all tools are mobile.
Re: Marc's Shop
Re: Marc's Shop
Marc
>The back wall which has some storage, shelving, and the DC cyclone (remote controlled via X-10)
Re: Marc's Shop
Re: Marc's Shop
Marc
>Looking in now. The right wall also has the wood storage, Planer, Jointer...
Re: Marc's Shop
Re: Marc's Shop
Marc
>Here is the backside of the Tablesaw, with the outfeed, routertable, and the lathe in the background.
Re: Marc's Shop
Re: Marc's Shop
Marc
>Finally, the workbench :) took a while to make, but well worth every minute of it.
Re: Marc's Shop
Re: Marc's Shop
Marc
>Another pic of the workbench drawers
Re: Marc's Shop
Re: Marc's Shop
>Good Afternoon Marc,
Lovely bench. I believe you when you talk about solidity! It seems at home in your thoroughly capable shop.
George
Re: Marc's Shop
Re: Marc's Shop
Fred Davis
>I'm with George .I like a bench that doesn't move around when you lean against it and yours does that really well , good job.
FredD
Re: Marc's Shop
Re: Marc's Shop
Marc
>Thanks George and Fred.
When I first touched a handplane, I hated it. A few years ago, I finally learned how to sharpen and that I needed a solid base to work on. That was a transforming event for me :) The bed and entertainment center that I just posted where mostly finished with handplanes and scrapers. Now, I despise power sanders :)
Thanks,
Marc
Re: Marc's Shop
Re: Marc's Shop
>Ah yes, I remember it well, so sings the song.
Now I get angina pain every time I try to use a hand plane or manually sand an expansive surface. Now is the time for me to pay the eleectrical bill.
George
Re: Marc's Shop
Re: Marc's Shop
Larry in NW Ohio
>Marc That is quite a nice shop, like the saying goes"You don`t need alot to do a good job" Excellent work. Larry in Ohio
Re: Marc's Shop
Re: Marc's Shop
Stuart Hough
>What size is your shop, Marc? Looking at it gave me a bunch of ideas for my 20x20 (nominal) garage...er...shop. I just need to find a spot for all the unnecessary stuff(like old family stuff, shutters, games, etc). Thanx for the pics!
Re: Marc's Shop
Re: Marc's Shop
Marc
>Hi Stuart,
I'm not sure of the exact dimensions, but it is probably 22' or 24' deep by 18' - 19' wide. I'll try to measure it later. I'm not sure the pictures show it, but there is a drop-down staircase to the attic area for storage :)
One thing I really like is on the back wall, to the left of the cabinets and shelves, I have a vertical compartment for storing plywood vertically. It is about 10" wide and stores most sheet goods that I need. If I had taller ceilings, I would have done vertical lumber storage, as that would be much easier to sift through lumber than the horizontal storage on the wall.
Thanks,
Marc
Re: Marc's Shop
Hope you don't mind…
Rod Peterson -- Ormond Beach
>I took the liberty of capturing the pics and text and transforming it into a gen-u-wine WoodCentral Shop Tour.
Sometime when you have the inclination, you may want to send me some better, bigger pictures (turn off "date stamp" if you can—save me some editing time), and refine/expand the text part, too, if you want.
Rod
Editor, ShopTours.org
Re: Marc's Shop
Re: Marc's Shop
Larry in NW Ohio
>Mark I was going through your pics again and noticed the DC, is that the one from a guy in Indi, IND. I can`t think of the name, maybe Dust sucker? Is he still around? Larry
Re: Marc's Shop
Re: Marc's Shop
mdclor
>Larry,
It is a Woodsucker. I have one and like it although I suspect the newer Oneidas are quieter. His name is Larry Adcock. I think I read that he got a bad review in one of the rags and closed up shop shortly thereafter, too bad.
Merle
Re: Marc's Shop
Re: Marc's Shop
Marc
>Yep, it is a Woodsucker, one of the originals. Unfortunately I think Woodsucker is no longer :(
Marc
Re: Marc's Shop
Re: Marc's Shop
Marc
>Hi Stuart,
I finally measured it, and it is 23' x 18' Send me email if you have any questions on things I have done.
Marc
Re: Marc's Shop
Re: Hope you don't mind�
Marc
>Hi Rod,
Thanks for posting it!!! Perhaps someday I'll clean it. There are some other pictures I would like to take :)
Thanks,
Marc
