18 ga brad nails
18 ga brad nails
18 ga brad nails
peter kolb
>I have had very limited success in withdrawing pneumatic 18 ga brad nails from stock. An example: made a mistake in nailing two pieces of wood together-separate the two pieces and there will be exposed brads.
In an attempt to remove the brads they will break. How do I do this without breaking the brads? Thanks for your help-Peter in south central nj
Re: 18 ga brad nails
ViseGrip pliers
>I remove them using a pair of ViseGrip pliers (not pictured), carefully pulling straight so they don't bend. They come out of pine and plywood easily, but I don't use brads in hardwoods, so not sure about that.
I also have a pair of end cutter pliers (pictured), and I find that if I apply just the right amount of pressure they can grip without cutting the brad and then I can roll the pliers and gently pull them out in a gentle curve.
The key to either method is to be gentle so that the brad doesn't break.
Hope that helps.
Happy Woodworking!
Larry in NW Ohio
>Pete I useually use a vise grip pliers, like mark talked about, and get a good hold of the brad and then use a claw hammer or a wonder bar. Then put a thin piece of ply down to protect your good wood if you need to. then pry it out. This has worked for me quite allot. Larry in Ohio
Bill Howatt
>I also use vise-grips and usually find that it is easier and makes less mess if you pull the brad through the stock rather than trying to push it back out. If it breaks off reasonably flush with the back side of the stock I just leave it there.
Bill
iew
>I use nippers. They have a round shoulder and make the job easy. Just grip the nail with just enough pressure to keep from cutting it off and roll the nippers.
Alex Grigoriev
>Try Extractor (google for Nail extractor)
