Pie cut drawers?
Keith Newton, LR, Arkansas------WebKitFormBoundary
>I have a customer wanting me to make a little drawer cabinet which will be octagonal, with wedge shaped drawers which are all of the way around on all eight sides. So each one will be a 45� triangle ~, except the back corner will be squared off, and actually a fourth side.
I was wondering before I bight off more than I can chew, if anyone had any neat trick for some sort of locking corner joint which would be better than just glue and brads, but not as time consuming as hand cut dovetails.
I will probably need to get a special cutter ground, unless there is something out there. Any thoughts?
To flesh out the project a bit more, there are 11 tiers high, so 88 drawers. Since there are actually four sides, 352 sides, x 2 ends, = 704 ends to cut on small some very small parts, I need something that can be jigged up for safety too.
