Stearated Sandpaper *LINK*
David
>Hi,
I been doin some reading on finishes and some that write the books say don't use a stearated sandpaper-apparently coated with a chemical that inhibits clogging. I went to the Norton website, and from what I gather, all there sandpaper is stearated when you look at the "3X" type sold at Woodcraft.
So, will the stearated paper sabotage my (water based?) finishes? or am I worried about nothing (has happened to me a lot, it's an affliction.)
The link below has the website info on it.
Thanks, David
http://www.nortonconsumer.com/Data/Element/Node/ProductLine/product_line_edit.asp?ele_ch_id=L0000000000000002553
Re: Stearated Sandpaper *LINK*
David Barnett - SW Florida
>Stearated sandpaper may leave cloudy residues which may appear dirty and uneven, although I like to use stearated 320 when sanding in an oil finish slurry.
David
>So, given that it doesn't say on the actual pkg that it is stearated, where does one find non-stearated sandpaper, what brand, etc?
Stearated paper
>...is almost always variegated in color, usually a marbled blue-gray color. The classic alternatives are garnet paper and aluminum oxide paper, but there are some recent, higher-tech products, including a mesh-screen abrasive (Abralox?) that is getting good reviews from turners and others. Somebody here or on the turning board will surely tell you the name and a source of supply.
I have not noticed problems caused by stearated paper in lacquer and varnish finishes, and I can't recall any with waterborne coatings, although I can't recall specific instances.
Re: Stearated paper
Fred Davis
>Ellis ,
I used Zinc Stearate loaded paper for about three years and I intially was sold on the non loading aspect of it.
I have since decided that advantage was barely detectable and the price negated any slight advantage over Aluminum Oxide paper.
Since I use Garnet to sand sealer , I havn't had any Fre-mite paper in the shop for a long time.
FredD
