I've got my bandsaw all tuned up and ready to cut some 1/16" veneers. Where does one order what would normally be sold as "turning blanks"? that will make beautiful veneer, but larger? I can now saw veneer, so I'd like to get some wood (burls, birdseye, etc) to make worthwhile veneer. I need larger pieces than 8" by 6" by 4". Any ideas?
>Our sister site, Woodfinder.com, has lots of suppliers who can fulfill your turning blank fantasies.
Give some thought, though, to your plan to saw veneers at 1/16". That's pretty thin. James Krenov and others recommend sawing at about 1/8" or slightly less, with the final thickness targeted at about 1/10". This thickness offers the appearance and solidity of solid lumber, with the ability to plane or sand it if necessary, while still behaving like veneer. Any thicker than that, and you will likely see the veneer shrinking and joints opening up.
This is anecdotal evidence. Your mileage may vary with the species and moisture content of the wood you are resawing as well as the adhesives you are using to lay up the veneer. Experimentation before commitment is a good policy.
>thanks for responding. I imagine you and Krenov are right. Last nite I found that woodfinder site and there are some truly large specimens out there, for the right price, of course. I might just have to saw regular walnut or mahogany and put on MDF to make whatever if it's larger than a "box". thanks again. David
>Also, remember if you do use turning blanks or other large pieces of wood the moisture variation, if there is one, will cause the thin pieces to curl. You will probably want to build a veneer press to allow the pieces to dry without curling like a potato chip.
I never have cut veneer from anything other than a green cant (once, and that was enough) but I would think the best results would come from dry stable wood.
