Seeking a Paulownia source...
Glenn Madsen in the SF Bay Area
>We looked on Woodfinder. Maybe we did it wrong, but essentially, it said: "Huh?"
My son has been building laminated surfboards, and has done a couple of nice ones so far. Our local lumber source (Plywood and Lumber Sales, in Oakland, CA) had a slab of paulownia, and it worked well. But they got it when they bought out the stock of another northern California seller, and it was one of those things that 'came along with the purchase'. They don't know where to get it again.
Any ideas where we might be able to find a couple of more slabs? Preferably without having to import it from Asia or New Zealand?
Re: Seeking a Paulownia source...
John McGaw
>It is processed by a few East Tennessee sawmills although I don't know that I've ever seen anything I'd call a "slab". Around here Paulownia is a weed species and I've never handled any more than about a foot wide, if that. I have a small stack in the garage right now and that is definitely all less than 8-inches. I'll try to check around with some of my contacts and will get back to you if I find out anything useful.
Charlie Mead
>My "Sawmill-Man" saws Paulownia on a regular basis. This is entirely "tomentosa" from the forest but some plantation grown. He saws with a Woodmiser, with which he is an expert - have had boards up to 24" wide.
Contact:
Max Reed
633 Whites Creek Rd. (Rhea County)
Spring City, TN 37381
423-365-9331
Max is not on the planet yet - does not have e-mail.
John McGaw
>I figured you'd know if anybody would, Charlie. Thanks for replying to my email so quickly -- you must have been sitting there waiting for me to send it.
Fred Davis
>If White Bros. Lumber is still in business at the Oakland end of the bridge into Alameda, they would probably have it , since they specialized in a lot of underused woods.
FredD
plenty of it in E. TN
Bill Tindall, E.TN
>It grows here in eastern TN as an ornamental in people's yards. An ugly tree in my opinion. From time to time some foreign buyer comes along and buys the trees to be shipped somewhere overseas for some specialty product. They get a good price for a good log. I have seen mountains of the logs piled along the road awaiting shipment. However, there is no local market and I have never seen a log at a saw mill.
That said, if you can find a local small mill in this area you might talk them into finding a log.
I can't see what is special about the structural properties of the wood that would make it a preferred surf board material. It is soft, light and doesn't appear to be strong. I would think that a board of fir or butternut would be much better.
Re: plenty of it in E. TN
John McGaw
>Paulownia, on its own, is certainly nothing to brag about when it comes to strength or durability. But if you combine it in a composite with, for example, fiberglass and resin you have an entirely different beast.
As an example you will find balsa wood being used in high-end yacht construction laminated between layers of fiberglass/resin material and balsa is not even as tough as paulownia. The key is that it is very light and nearly incompressible if used appropriately and it maintains the spacing between the strong outside layers yielding an amazingly seaworthy hull for those willing to accept the cost all of the hand work in the construction. Personally I prefer a closed-cell PVC such as Klegecell for hull cores but it is probably not a coincidence that this material is provided is a brown wood-like color likely to please the traditionalists -- they could have made it fluorescent orange just as easily.
Alexander Grigoriev
>Balsa has been incorrectly considered to have the highest strength to weight ratios of any wood in the world.
Paulownia has been thoroughly tested and found to have a higher strength to weight ratio than Balsa!
It is rot and insect resistant.
Paulownia is flame-resistant because of high mineral contents.
Paulownia is air-dried very fast (30-60 days) or kiln-dried in 24-28 hours to 10%.
Lighter grades of Paulownia weigh only 14lbs per cubic foot. This is lighter than many Balsa grades.
When considering the large amount of epoxy that Balsa soaks up, Paulownia gains an even larger weight advantage.
>Paulownia is the most common wood in traditional Japanese case work (tansu) because of its super stability, lightness, and relative strength. It's easy to work and takes a crisp edge. Here's a shot of some cabinets I redid using it for door frames and drawre faces. The wood is from a tree I harvested and had sawn up.
Clint
it's also known as Kiri
Robin Corell in Atascadero CA
>Fred, they are still in business there. I hadn't thought of them as a source, since they are so focused on the building trades. We'll give them a call and see what, if anything, they have.
Thanks!
>That's pretty much how the board shapers are using it.
Jac built a board that is essentially an airplane wing-like structure, light laminate over a 1/4" Finn ply frame, and glassed it in. His last one was 11'. He's looking to build an even larger one, since he's a rather large fellow, and would prefer to surf on top of the water if possible.
The last several came out quite nicely.
I'm checking out Fred's suggestion, before we look to import from E. TN.
Thanks!
