>Is it better to soak turned bowl in dennature alcoholor or in a soap solution? The bowl is Honey locust 10" diamter, x 5 1 /2" high turned with a 5/8" wall. I can coat the bowl with anchorsel or or i can
begin wrapping the outsid and lip
with paperl after the alcohol. Which is best? What kind of soap?
>Galen, At 5/8 you are near the limit for drying and turning that bowl again. I have little experience with alcohol soaking and none with the soap. (As Lee said, go over to the Turning Forum for more on that). But, if your bowl warps as they often do when they dry, you may find there is not enough wood left to make it round again. I don't know if Locust is a wood that warps a lot, but I suspect it is. If it becomes only an 1/4" elongated (not unusual) you may not be able to true it up again.
Consider turning the bowl to finished dimensions still green and letting it warp.
>Thanks for comments and link to article. Seems 5/8 thick may be too thin to turn and let dry from what you say. Guess I will find out. I did anchorseal one and another is in alcohol bath since last night. I did find an article that says it just may be alcohol in the soap solution that does the same thing and just alcohol more straight forward.
Never thought of truning all the way green as it seem like it would be difficult to sand out. Just learning so I can try anything.
