473
![]() ARTICLES & REVIEWS by Dave Smith Drying roughed turned bowls has always been a challenge for wood turners. You need to balance the desire to finish a piece as soon as possible with the inherent tendency of wood to warp and split when dried too quickly. Wood turners have employed various methods to maximize the drying speed while minimizing the degradation of the wooden shape being created. Over time each method has collected its own supporters and detractors with respect to the relative effectiveness of the process.
Here is a set of roughed out apple bowls that were cored from the same block. After more than a year they are still in good condition and ready to turn when I get a chance. The Process: Bowls are roughed out to 1/2 inch wall thickness for pieces less than 8" in diameter. Over 8" in diameter, I leave a wall thickness of 5/8 to 3/4 inches. Since my lathe is limited to 12 inches, I have not tested bowls larger than that for optimum wall thickness. I often turn utility pieces with a finished wall thickness of a quarter to half an inch. In these cases the roughed out wall thickness needs to be thick enough to allow for distortion. No drying method will completely prevent movement of the wood when it dries, so plan your roughed out blank accordingly.
Once the bowl is roughed out it is submerged in denatured alcohol for at least 2 hours. Larger, thicker bowls need to soak longer to ensure good penetration of the alcohol. Longer soaking time does not appear to damage the wood. ![]() Remove the blank from the alcohol and let it air dry for about an hour to dry the surface.
Now wrap the outside of the bowl in heavy paper such as a grocery bag. Secure the paper with a couple of wraps of masking tape around the rim. Fold the paper over the rim, trim off the excess, and place the bowl upside down on a rack to dry. If the bowl set on the foot it may not rest evenly due to the paper and the air may not circulate as well. The inside of the bowl needs to be exposed to air. The reason for wrapping the outside only is the theory that it will create a compressive stress on the bowl by drying the inside quicker than the outside. As the inside dries it shrinks which pulls on the outside causing it to compress. This compressive force minimizes cracking during the drying process. Thinner walls yields less distortion and fewer cracks by decreasing the maximum stress developed between the inside and the outside. ![]() The solution does collect wood dust and other debris over a period of time, so I strain the solution when transferring between containers. A kitchen strainer place across a container with a paper towel filter is sufficient to remover the big hunks. Containers used for storing soaking alcohol should be non metallic. Alcohol is about 95% alcohol and 5% water when purchased. As bowls are soaked in it, the moisture content of the solution will increase, which, along with other impurities leached from the wood will attack metal containers. I use plastic ice cream containers for soaking bowls and storing used alcohol. A one gallon container will accommodate a bowl 8" in diameter by 5" tall. A two gallon ice cream container will hold a turning 8 1/4" in diameter and nearly 10 inches tall. ![]() For larger bowls, a 13qt stainless steel bowl will accommodate 13" diameter bowls that are less than 6" from the rim to the bottom of the foot. ![]() To cover a large bowl, place a sheet of heavy plastic film over the steel bowl and secure it by wrapping the rim with clear packing tape. If you stretch the tape, the cover can be removed and replaced as needed while providing a reasonably good seal. Still larger bowls can be placed in a heavy plastic bag and then nested into a pile of shaving to conform to the bottom of the bowl and limit the amount of alcohol needed to cover the bottom. The inside of the bowl can also be filled to reduce the volume of alcohol needed to completely cover the bowl. With a little bit of ingenuity the amount of alcohol required to process large bowls can be held to a reasonable quantity. Other Trials: In order to verify the results I had obtained with alcohol soaking, I asked several other tuners to try it. I wanted to get a cross section of turners with different experiences and specialties. Some of those who provided data included Bill Grumbine, Dominic Greco, Mark Kauder, and Jennifer Shirley. Mark Kauder has used the method for 3 bowls, two from box elder and one from sycamore. He bought a slab of freshly cut Ambrosia Sycamore, 4" thick and not sealed. He cut three 16" diameter blanks from it, roughed them out, then used the alcohol soaking method on one of them while completely covering the other two with Anchorseal. When he later pulled them out, the Alcohol Soaked on seemed dry, and had warped only about 1/2" across the grain. When he turned it, it was dry, and has not moved since. The two Anchorsealed ones had both warped/shrunk 1" across the grain and had "Potato chipped" or cupped about 1/2". After chucking them up and getting them round again, they still continued to move. Mark reports he will use the alcohol soaking method when he turns solid Wood. Dominic Greco has completed more than a dozen pieces using the alcohol soaking process. He has used the process on many types of wood including; Box Elder, Norway Maple, Osage Orange, Cherry, Chinese Elm, and Apple. When asked what the worst problem was Dominic responded, "The piece of Osage Orange cracked during drying, but I believe this was a crack that was present in the blank, and not a direct result of drying". Dominic uses a moisture meter to determine when a bowl has completed drying. After 2 weeks he reports that his pieces are at a moisture content of 6%. None of his finished pieces have distorted as of the writing of this article, and Dominic reported that it is now the only method he uses for drying bowls. Bill Grumbine used the alcohol soaking method in late 2003 to fill Christmas orders he received during a Thanksgiving artist show. Bill has been an enthusiastic supporter of the method. Jennifer Shirley soaked one walnut bowl before reading the fine print as, she calls it, and left it in the alcohol for four days. When she removed it, she simply left it on a shelf exposed to air. Four months later the bowl exhibited no problems other than the normal out of round when she finished turning it. Conclusions:Although I collected data in a consistent manor and attempted to control variables, this is not a strict scientific study. The study did not verify my theory of why the process works. The study does show that soaking green roughed out bowls in alcohol does reduce the time necessary to bring them to equilibrium with their surroundings. Wrapping the outside of a bowl reduces distortion and checking. Testing by other wood tuners has verified that the protocol works consistently. The process is simple and relatively fast. The expense of denatured alcohol is minimal compared to the savings in reduced bowl losses, but the biggest saving is time. Using the alcohol soak method reduces the drying time for roughed out bowls from months to weeks. . . .
Dave Smith
© 2003 by Dave Smith . All rights reserved. No parts of this article may be reproduced in any form or by any means without the written permission of the publisher and the author. |
