Homemade Remote Control for D/C
Jim Vest
>I want to make my own remote control for a dust collector (220v 18a, does anyone know how to do it or have a link that I can go to for the plans. I would prefer the R/L kind?
Thanks,
Jim Vest
Thanks,
Re: Homemade Remote Control for D/C
Dan Donaldson
>Do you want to make it for fun, or to save money? If to save money, you will probably get by cheaper by buying one ready made.
Fred Davis
>They's no longer cheap Dan ;-))
FredD
$70 aint cheap but it aint pricy either
Forrest Addy
>http://www.highlandwoodworking.com/browseproducts/110V-Long-Ranger-Remote-Control.HTML
However DIY is always a pleasant challenge
Mike Jurnigan in Suffolk
>I made mine years ago. The plans were in Fine Woodworking. It used a Radio Shack remote light switch device and it worked a 110 to 220 relay. Do a search of the FWW Index. All the parts that were used in the plans except the remote switch came from Granger. It even had the catalog numbers for the parts.
Mike In Suffolk, VA
Dan Donaldson
>That is true, but unless you can find the parts surplus, there is a good chance it is going to cost at least as much as a commercial unit and depending on your skills, may not work as well. That said, it is also fun to build stuff yourself sometimes and if that is your goal, go for it.
Larry in NW Ohio
>You can get a remote switch under$20 on Ebay, look under "Remote Control" I have at least 6 of these to control various objects in the shop and around the house. Larry in Ohio
Ken Garlock, Collin County Texas
>OK Jim. The question is do you know which end of a soldering iron you pickup? Do you know what a solid state relay is?
IF you can answer YES to both of the above questions, I will post what I did to automate my cyclone dust collector.
Otherwise, I don't want to further confuse the thread.
Happy sawdust,
Ken
I know both those things, Ken
Dan Mitchell
>And then some. I even have a couple solid state relays laying around here someplace. Please email me any info/schematics/etc you have.
To me, the "remote control" approach is an improvement, but I'd prefer something which powers up my 240v DC when I turn on the TS, jointer, etc., preferably letting it run a few seconds after the tool shuts off. I find I tend to leave the DC running constantly, to avoid the PITA of turning it on & off constantly, which I know is not a good thing from a noise level or crap in the air standpoint.
Thanks in advance,
Dan
>Jim There has been a 3 part article running in Woodwork magazine for the last 3 issues. It is homemade but doesn't look cheap. It has automatic blast gates. I bought a remote control from Penn State Industries and couldn't be happier with it. I do have to manually open the gates but I've dropped and just generally abused the remote for years and it's still working fine.
Re: I know both those things, Ken
>Dan, I use the blast gates that have the micro switches on them. The Long Ranger version. I spent a lot of head scratching time figuring out the system so that the blast gate is in an easy convenient position so that it is a "natural" to open the gate then turn on the machine and then reverse the process on the way out. Works well.
Wonder if you could use the eletric eyes from a garage door to do the same thing? I know you can do it with a current sensing coil on the circuit for the tool.
It is stunning how quickly the DC becomes the "standard". Occasionally I make a cut without using it and I am stunned at how dusty the process is. How did I work with the same stuff for thirty years before I installed the DC?
Automatic control of Cyclone DC
>This will probably be a clear as mud, but here goes.
Over view: I use a small 12V power supply to energize two solid state relays. Control of the off/on function is by a CR Magnetic current switch located on ONE leg of the power line of the individual tool being used.
This is not a blast gate solution, that is a project I have yet to tackle; I still operate the blast gates by hand. I think I will look at the Woodwork mag. article....
OK, here goes.
1) build a power supply. A wall wort might work but I put more faith in a real transformer. You need a
12V 1-amp transformer, 120v primary
full wave bridge solid state rectifier, 50v, 1-amp
4700 mfd 35v electrolytic cap.
power cord
spst switch for transformer primary. I put a neon pilot light on also.
Build PS on small piece of plastic.
2) Switching the relays.
You need 2 spst 300v, 50 amp solid state relays
A plastic terminal strip with screw down connectors. The strip should be the "shorting" type where corresponding screw downs(left and right sides) are connected together. I have 6 on mine and I should have had more.
15,000 mfd 35 v electrolytic cap. I used 3 4700s in parallel.
Spool of hookup wire from Rat Shack.
Use a piece of 3/4" ply/MDF to mount everything:
Mount the two SSRs, power supply, and terminal strip. I put the terminal strip below the SSRs and the power supply to the left.
Wire the following wires:
PS neg to neg on each relay, one wire daisy chained is fine.
Down one side of the terminal strip run one piece of stripped bare hookup wire between half of the screw terminals ON ONE SIDE. Run another wire between the other half terminals on the SAME SIDE.
Attach the positive wire from the power supply to one of the "half daisy chains. Run a wire from the other "half daisy chain" to the positive terminal on each SSR. When you are done, you should have one side of the terminal strip with nothing on it. The other side of the strip is split in half, one half has the voltage from the power supply. The other half has the connection to the SSR.
Connecting the Cyclone:
Disconnect your 240V line to the cyclone. Cut the cable in two such that you have two pieces of cable that can reach the SSRs with slack to spare. The next step is simple:
connect one leg of the cyclone motor wire to one side of one SSR. Connect the same color wire from the 240V line to the other terminal of the same SSR. Likewise connect the other motor wire to the other SSR, and the same color from the 240V line to its other terminal. Twist the ground wires together....
Note the SSRs will have two terminals labeled control, and two labeled load. They may have labels on the load side that further defines which load terminal is the real load(motor) and which is the supply(240V). I have forgotten. Never get the control and load wiring reversed.
Since you will have some bare low voltage wires and some 240V terminals bare, I used a sheet of Plexiglas bent in a U shape to cover the mounting board. All you NEC patrons will no doubt have a fit. My control board is located in the corner out of the way of all traffic in the shop. There are no moving parts to cause sparking.
Everything is wired up, but we can't yet switch on the cyclone. For that we need a length of thermostat multi conductor wire. Run said wire to the screw terminal strip. strip back 6 or 8 inches of the outer jacket of the cable. Next run the cable from the controller to each of the tools that have a DC connection. Here again, I daisy chained the wire between machines.
Now the hard part, up to now it has been a smooth ride....
We now need to install our sensor that detects the machine is drawing power. For that I used the CR Magnetics CR9321 NPN current switch.
A few words about the current switch. The switch is about the size of a silver dollar with a hole through the middle. ONE lead of the machine power is passed through the hole. When the used presses the button on the tool, a magnetic field is set up on the wire as the motor draws current. The current switch switch acts like a miniature transformer and generates a small voltage that is rectified and used to cause an NPN transistor to conduct. That transistor is the actual switch in this package.
Hook up the a pair of the wires in the thermostat cable to the two wires on the current switch. Back at the controller, hook the same pair of wires to the empty side of the terminal strip. One wire to the side with the positive power supply, the other to the half with the lead to the SSR.
IF we have done our job correctly, the cyclone should new turn on when the machine is turned on. However, it will turn off as soon as the machine is turned off. It is nice to be able to clear the pipes of the cyclone, so I introduced a 15,000 Mfd capacitor across the negative and positive terminals of the SSRs. The cap is charged when the machine powers up, and slowly discharges when the machine is powered off. This gives me about 8 to 10 seconds of delay shut off for the cyclone.
So that is the cliff notes write up on my home brew controller. Yes, I have skipped a lot like building the power supply.
IF you can figure all this out, tell your boss you need a raise. :-)
Happy reading,
Ken
Remember to eschew obfuscation by
avoiding Egregious Sesquipedianism.
Re: Automatic control of Cyclone DC
Dan Mitchell
>The main bugaboo is sensing that the TS etc has turned on, the rest is pretty basic. I was not aware of the existence of the CR9321 & its variants, I see Digikey has them. I may order one to play around with, perhaps working out a wireless arrangement in combination with a remote light switch to turn on the PS/relay/DC. Thanks for the info.
Dan
Bob Entwisle in NJ
>I agree with you Dan, Too easy and cheap to just buy one. I guess I'm jaded by having designed and built all kinds of electronic gizmos for a living. It's still fun, but mostly only from 9 to 5 M-F.:)
Bob
Here you go... *LINK*
Garrett in Victoria
>My article on building a cyclone includes the instructions you require for a DIY remote control. Scroll down to the middle.
Cheers, Garrett
Garrett's Cyclone Article
