A55 Smoothing Plane
a little help needed
Robin Corell in Atascadero CA
>Smetimes it is hard to be able to objectively look at a pic of something when you already know what the actual object is. I have just such a case at hand. I would really appriciate a few coments regarding peoples impressions about how big they thing the lamps in the picture are.
Thanks in advance
Robin
Re: a little help needed
North of the Border
>Assuming a regular sized light bulb is used in the lamps, the lamps should be about 14" - 16" tall.
Dan Mitchell
>Assuming the bright spot in the left lamp is the typical one you might see from an incandescent bulb, I would guess they're about 60" tall x 10" wide, if not a bit larger.
Dan
Keith Newton, LR, Arkansas------WebKitFormBoundary
>I think they are probably close to 7' tall. I would bet they started with 16" sonna tube, and veneered it with butcher-block plastic laminate.
Lee Grindinger
Photographing work
Lee Grindinger
>It's clear you're now facing this issue head on. Furniture and many furnishings need something in the pic to scale it. Items also enhance an item, clients are often looking for a feeling as much as an item so make a mood for your shots. Sexy women sell cars that barely get shown in commercials. these agencies know they're selling a mood or feeling, take note.
Include something in the pic to offer mood and scale, like this for instance...,
7 feet
I agree with Lee
Dan Mitchell
>Robin wasn't really clear on the origin of the image. If these are lamps you have made for sale & this pic is supposed to represent them to potential buyers, you really should add something that indicates the scale. Show them in a setting typical of actual use.
John McGaw
>Not knowing anything at all about them I could only apply a wild surmise about the size of the light bulbs and guess that the cylinders are about 3-1/2 feet tall. Of course since I can't tell what sort of bulbs are involved that surmise is probably rubbish.
I agree with Marc-staved construction-7'
Brian in Brighton
Thanks, and a little info on the first pic
>Thank you to all the replies. I apologize for being so ambiguous in my original post but I really wanted a gut level first reaction to the image in the pic. The lamps are 7'-6" tall with the cherry lamp being 13.5" in diameter and the spalted maple lamp being 16.5" in diameter. They are both 55 staves, laminated construction with a wall thickness of 5/8"(maple) or 3/4"(cherry). I have a pic of one in spruce on my web site that was taken in the client�s home. These were the first ones that I took studio shots of so I could use them to apply for next years ACC show. Most of my work is some what self explanatory as far as scale. a chair is pretty much chair size and even tables have a pretty narrow range of heights as compared to the responses for how tall these lamps are. I debated about using the attached pic for the ACC application as I feel it is less ambiguous as to scale, perhaps next time I will.
Robin
I would have guessed 6'
>Nifty design, Robin. How did you figure the coopering angles? Are there some kind of floating discs inside the cylinders to keep them from distorting or breaking if tipped over?
I'm always curious as to the thinking process -- the functional, aesthetic, engineering, logistic and cost considerations -- that drive the design. Since you will be showing these at an ACC show, I assume the design problem was to make a tall, minimalist, torchere-type ambient light fixture that is modern looking and not too complicated to lend itself to limited production. But I'm sure there were other motives and considerations. Wanna tell us more?
how I make these
>The first one of these I made was made out of spruce and the design was inspired by the wood. I only had a couple of 11' 2x14 slabs so the amount of wood I had was a factor but the most significant factor regarding the wood was the type of wood. I wanted to do something that was about the Golden Spruce tree, a very special singular tree on Queen Charlotte Island, BC. For those that don't know the story of this very special and sacred tree it is worth a Google. I couldn't think of any ideas and then one morning I woke up and knew what to do and started on the first one of these lamps. It may sound corny but that was how I ended up making the first one of these lamps. I don�t usually work in a modernist style, though I do take inspiration in mid century design it is usually the Egyptian or Chinese influences behind mid century that inspire me more.
The angles are all just straight forward math, 360 degrees for a circle divided by the number of staves. That gives you the included angle for each stave and you divide it by two to get the angle for each edge of the stave. The width of the stave multiplied by the number of staves will give you the circumference. Divide that by 3.14 and you get the diameter. the thickness of the staves is not that important, it is easier to keep things straight when ripping all the angles if the thickness is noticeably different from the with and you don't want to make it too thick in order to keep the weight down.
I use hot hide glue because that is all I ever use. I usually only use my pin nailer for making crates but I do use it to pin the staves as I build this lamp. It takes me right at a full day to assemble one once all the parts are cut and the staves are laid out for color and pattern. This holds true if the staves are full length of if half are two pieces. On the cherry lamp I didn�t have any staves that were full length and most were three pieces with some as many as five pieces. This added another several hours to the assembly. This is still a new design and I am tracking time on all the processes and refining some of my methods.
I assemble the first few staves on the bar for my rip fence as it is long and straight. Once I have about 5-6 staves I then use a set of cradles and just build it one stave at a time. The last three staves are assembled without nails and this is where the hot hide glue shows its real advantage, though these three staves take more time than six staves assembled with the pin nailer.
There are no internal supports and it doesn�t feel like it needs any. For the top I use a floating disk to locate the shade and this disc is segmented construction so that it expands in all directions similar to the shaft of the lamp. Another advantage of not having internal supports is that I can slide the smaller on inside the larger one when packing up for a show, no small thing when driving 1000 miles.
I make my own shades out of brazed hot rolled 1/4 steel rod and an industrial membrane treated with natural oils and plant resins. The bulb is 25w and is one of those long skinny ones used to light a picture or a display case. I have tried 60w or compact fluorescent bulbs and I prefer the color and brightness of the 25w bulb.
The first lamp sold on the second day of a three day show and these two pulled in people like moths at my last show. The cherry one may end up being sold along with a commissioned one slightly smaller. If not both lamps will be in my both at the up coming San Francisco ACC show Aug 15-17.
I like them a lot
Dan Mitchell
>Nice modern look. I'd love to see some internal pics of the construction.
Re: I like them a lot
>Sorry but I don't have any pics of the construction process. The inside looks just like the outside before I sand it, only curved in the opposite direction. There are no internal supports so it is basically a big hollow tube before I put the floating disc on top to mount the electrical socket and register the shade to the column.
Robin
Re: I like them a lot *LINK*
Dan Mitchell
>Thanks for the reply, Robin. I get the stave part, and I was thinking a couple circular masonite disks fit into grooves at the top & bottom of the tube, barrel-fashion, might be useful, especially as an assembly aid.
But actually, it's the SHADE that has me most baffled ;-) For material, I was thinking linen might be good, it's rigging up/attaching/perfectly rounding the frame that I'm wondering about. I see you brazed yours, I don't have such gear (though I used to... ) I wonder what other method might work?
BTW, I looked up the ACC after reading this post. Very intriguing. A terrific woodworking gallery in Seattle (where we live) is apparently affiliated with them:
http://www.nwfinewoodworking.com/index.html
>The shade is something that I worked on for a long time before coming to the solution I did. I came up with several variations that I ultimately gave up on because I felt I would not be able to recoup the time. Linen is a very traditional material for lamp shades as is silk. I never looked at either of these but both would work. True parchment or rawhide was another solution I looked at and it has a wonderful look. True parchment is very expensive and may be nearly impossible to find in single sheets in the size necessary for this size of shade. Mica is another solution that looks great. Either of these would need an entirely deferent style of support.
Any disks on the end would ultimately cause more problems than they solve if they are left in as part of the construction. Anything that connects the opposite walls on a staved piece needs to be fully floating or it will self destruct. Barrels and buckets are different because they are designed to stay wet, or more precisely at a constant moisture content. If you do the math using a wood movement calculator such as the one on wood web you will quickly see this. You need to figure the liner movement for the circumference and then divide that by pi to find out the change in diameter.
Lastly all of my designs are copyrighted. This means that it is not ok to make one for your self. I have shared some of my construction details with you in hopes that you will use my design as inspiration along with this info to come up with your own unique design.
Robin
Thanks, Robin
Dan Mitchell
