Have a question? Ask Woody!
Cutting high pressure laminate on the TS
Dan Mitchell
>I have some "Formica" I need to cut for a router table. Can I do this on my TS with its WWII blade? Any precautions?
TIA
Dan
Re: Cutting high pressure laminate on the TS
Dan Donaldson
>If it is the thin stuff, be careful that it doesn't get under the fence as you pass it through and hold it down so it doesn't flutter as it passes the blade and create a kickback situation. (it likes to shatter into sharp little pieces if that happens ;-)I have cut it on the tablesaw, but I prefer to use a trim router to get it to approximate size, then finish it off after it is laminated to a substrate.
Neal in San Jose
>Easier way to do that is to score it with a Stanley knife and snap it. Cut it a little oversize, glue it to your router table top and trim it to size with a trim cutter in the router.
Fred Davis
>The trick to cutting "Formica" on the table saw is to hold it up at about shoulder high and tip the left outside up corner a little and run it through, this avoids getting it under the fence and is by far faster then any way I ever heard of and the way I did it if I had a job I could not avoid in plastic.
Cutting oversize is a must, because the saw cut is not as smooth as the router finish cut.
FredD
Gary Camp, Bend, oregon
>I have a piece of 1 X 4 X 1/8" Aluminum angle about 6ft long that I clamp to the saw fence when I cut p-lam or FRP on the table saw, keeps the edge from sliding under the fence and helps take some of the "flop" out of the thin stuff. I also use the score ans snap method alot.
glc
Dan Mitchell
>Thanks for the replies. I do have one of those carbide tipped scoring tools I used on this sheet when I cut it in half to make a TS outfeed table, which of course I trimmed w/the router once glued down. The snapping worked, but kinda rough.
Dan
>While I use the score n' snap method, it is difficult to snap edge stripping that way.
The solution is pretty easy.
1. Get a piece of flat 1/4" plywood about 18" wide by 3" longer than your saw's table is wide. You'll also need a couple of 12" pieces of 1x2.
2. Drop your blade, remove the splitter, and back your fence away.
3. Glue or screw one of the 1x2's square across one end of the ply.
4. Place the ply on the saw table covering the blade slot with the attached 1x2 strip snugged against one table edge (front or back), and attach the other strip under the opposite end of the ply so that it "locks" the ply in place as a table cover that won't slide front-to-back.
5. Remove the ply, raise your blade, and set your fence to the width of the cut you want.
6. Drop the blade again, and put your ply back in place set tight to the fence.
7. Turn the saw on and, holding the ply down with a piece of wood (away from the blade area), raise your blade to cut up through the ply to about 1" above the ply surface, then lower it about 1/4".
9. You're now ready to cut the laminate (good side up) to the width you set. The ply acts as a zero-clearance throat plate for a smooth cut and also prevents the laminate from sliding under the fence. You get precise strips with good edges and minimal waste.
The ply can be reused for different width cuts until the blade starts making bigger slots that won't support the laminate cut-edges well enough.
Note: For cutting long (8-12 foot) strips, score and snap a working piece of laminate that is sufficiently wider that the total number of strips you'll need. This is much easier and safer than trying to shave 1-1/4" strips off of a 4' wide sheet.
mm
i do the same as Mark only
Keith Newton, LR, Arkansas------WebKitFormBoundary
>I make it a little longer on the outfeed side because my catch table is about a foot away.
Drywall zippy or jigsaw
>I've always used a drywall zippy cutter tool (Dremel on steroids) or a jigsaw with a fine metal cutting blade on a slow speed. Cut about 1" over sized all round, and then trim with a trim router after it's glued to the surface.
Happy Woodworking!
>I like Mark's Idea of a table cover/giant zero clearance insert, but I have never done it.
I have glued the full sized piece of laminate to the blank and then used an edge trimmer to trim off the balance of the sheet.
I have also just taped a piece of wood about the size of a yard stick to my TS table beside the fence to keep the edge out from under it and just sawed. The WWll blade will work fine. Cut face up on the TS
And I have used a jig saw with a fine metal cutting blade to hack up large sheets. Cut from the back, but be care that there is no crud under the sheet that might scratch the face.
Roger Lance in GR, Michigan
>Dan...I know you were seeking TS methods for rough cutting laminate, but I've found that a trim router with the bit from an inlay kit works very well with minimal waste.
Robin Corell in Atascadero CA
>Many years ago I worked in a shop where we cut more formica than I care to remember. We had a 12" x 48" piece of 1/8" tempered masonite with a large rectangular hole cut in it so it could slip over the top of the biesmyer fence. This effectively blocks the area whre the formica can slip under the fence and for narrow strips the saw can be raised up throuh the masonite so it can act as a zero clearance throat plate. The masonite moves with the fence so on narrow strips you will need to lower the blade when changing diminsions but for wide stuff the fence can be moved with the blade raised. The real beauty of this method is its so eligantly simple and does not require any clamping or screws.
Robin
Fred Davis
>Now that is a tip worth remembering
FredD
Dan Mitchell
>Thanks for the replies. I had wanted to cut edging, which was my main concern, doing a bunch of long strips with scoring tool is a bit of a pita. I got the sheet at a Borg, went back & looked, expecting they might have edge banding in strips or even a roll maybe 3" wide to match the 4x8 sheets, but I guess that would make too much sense.
Dan
Andy Lincoln,in Dearborn,MI
>This is exactly how we do it at the shop I work in.We probably only do a similar cut 2000-3000 times a year.A power slitter works well when the sheets are down to managable sizes,but not an item that most people get enough use from to warrant the cost.
Andy
