>I just got a cast iron ash clean out door to replace a rusted one on a brick chimney. The old one was stamped sheet metal, mortared in place. While searching for these online, one site mentioned they could be attached with silicone caulk. Heat isn't an issue, as the door is outside & well down from the fireplace, but the door is fairly heavy, about 8 lbs. Would silicone be a good material, or would construction adhesive (or some other approach) be better?
>Don't rely on any adhesive to attach your access plate.
The whole frame and door need to be inset into the masonry (I'm assuming you don't have a wood-framed chase), and the weight of the assembly should be borne by the masonry.
If the new part is larger than the existing masonry opening, you need to open the hole up.
If the new part is smaller than the opening, you're in luck. Wedge the new assembly in place securely, using masonry. That can be small pieces of brick, or stone. After it's wedged in place, use Type N masonry mortar to seal around it. Make sure the bottom of the opening has a "wash", sloping to the face of the masonry wall. Don't leave any ledge, or flat exposed horizontal surface for rain to puddle on.
If you have to use wood wedges for this, remove the wood wedges after the first pass with mortar has dried well, then point up the holes to get a good tight mortar joint.
>Thanks John, the door has a flange around the outside which overlays the bricks, so getting mortar into the gap between it & the bricks will be a challenge. Any tricks for that?
>I'm no expert on these doors but it sounds like one option is to set the new door on a mortar bed on the bottom only. For the top and sides, maybe you could drill holes for anchors and screw the top and sides into the sleeves in the chimney.
>I got a 10# bag of Quikrete mortar at the local hardware, put a mound of it on the bottom of the opening, then "buttered" (see how good I'm getting at this? Even know the nomenclature! ;-) the top of the door frame & slid the ass'y into place. Holding it there, I packed mortar around the other 2 sides & any remaining gaps from the inside through the open door, then I made a nice bead all around/behind the outside flange where it meets the brick. Blocked it into place overnight, & when I tried it this AM, it was solid, so I guess I did alright. I'm sure this is stronger than anything from a tube, and at 3 bucks for the bag of material (which I only used half of) cheaper as well!
