Veritas - Innovation in Tools
Request for ideas about a window arch
North of the Border
>I have an archway window (like the one shown in the pic) in the family room and sunlight shines through it on the TV screen. Does anyone know of any idea or design using wood that would allow me to cover the arch but people from outside or inside see it like an artwork? My last option is use blinds. Thanks.
Re: Request for ideas about a window arch
Re: I found this. Does anyone know how to *LINK*
North of the Border
>make it? It's really expensive for a window arch.
Hunter Douglas Duette EasyView Moveable Cellular Arch
The actual product
how about this
Robin Corell in Atascadero CA
>The attached pic is of half a large gable vent I made for my house. This is patterned after the arched and eliptical fans I used to make as a subcontractor for a shutter company. The lay out for the overlap and the bevels on the edges of each blade is critical and for most wood workers would be a good challenge but it is not too dificult.
Robin
How about a radial blind?
Forrest Addy
>How about a radial blind? More like a jalousy built so the blades turn either way and deflect the light away from the TV regardless of sun angle. Done in nice wood and with beveled edges so they fit tight together the thing will look like a solid panel. Work it with a pole.
Fred Davis
>Never tried wood, pretty cumbersome I would think, but.....I had several clients over the years that would put stained glass inside the arch in a heart beat, generally flowers, mostly Iris.
Fredd
Jim in Burlington Ont.
Stained glass
>If you use opaque glass very little reflective light show's thru.
Curly Smith
>Intarsia - you can buy patterns for just about anything so you may have more difficulty deciding than doing. Or, design your own...
Bart Goldberg
Bart Goldberg
>Hi - I had the same problem - with three arched windows in my family room. I had three different stained glass windows made that are of a common theme. They work great at dealing with the problem your describe.
Regards
Bart
