Re: Afew woodworking aphorisms
Alex Grigoriev
>� Edge-to-edge joints should always be sprung
OK
� BLO makes the figure �pop� and enhances chatoyance
Flood with garnet or amber 2 lb shellac instead, keep wet for a while by continuing padding it, then wipe dry fast with a cloth. You then don't have to wait for long (compared to BLO) to get it completely dry. Oh, and warnish will be OK on that, unlike BLO. And it hardens soft woods (like pine and alder) somewhat.
� Glue joints should be roughened
Only if glazed, and you just change one bad to another bad. You want the joint clear cut with sharp blades, not beaten up.
� The more clamping pressure, the better
You just have to bring low spots together. If the surfaces are jointed well, it takes less pressure. If you roughen them, more pressure is required; and it will be inferior anyway.
� Lots of squeeze out is good
Jost more mess. You want to spread the glue uniformly first. Unfortunately, yellow glue then will thicken fast. But if you just apply a bead, visible uninterrupted sqeezout is just a sign of enough glue and full coverage.
� Out-of-the-can finishes need to be modified with BLO and various solvents
Just a superstition. If you want the finish to be less wear-resistant, go ahead, add BLO.
� Raw wood must be sealed with shellac before finishing
Depends on what you want
� Polyurethane finishes are inferior
Better than BLO, though. And there are poly and poly. Much variety.
� The hidden side must be finished the same as the show side
For a thick wide board, and seasonal humidity variations, yes, you better do.
� Biscuits do not strengthen a joint
But can help to align it during glueup.
� FESTOOL tools are really worth it
Maybe. Not in my budget.
